Which side of the caliper moves?
Old May 7, 2009 | 05:16 AM
ahickman's Avatar
I have an 86 Runner that has a sticking front right brake caliper. Noticed that only the pistons on the outermost side are compressible. I would have thought the pistons on both sides would travel when pressure builds up in the caliper cylinders. Anyone know if the inner side pistons should expand/contract? I would have thought the pistons pushed from both sides since the caliper itself is bolted directly to the hub and would otherwise warp the rotor.
Aaron
Old May 7, 2009 | 05:38 AM
TNRabbit's Avatar
They should push from both sides.
Old May 7, 2009 | 05:57 AM
GSGALLANT's Avatar
You are correct. All four pistons should move freely. You can take the caliper apart to rebuild it with a new seal kit, but if some of your pistons are sticking, you will likely find that those pistons have corrosion pitting on them, which means you'll need to buy replacement pistons also. Depending on how many pistons you need, you may be able to buy new remaned calipers for similar price (although I'm sure in the US, you guys can get pistons for $10-$15 a piece... up here, they were over $30 canadian each).
Old May 7, 2009 | 07:34 AM
ahickman's Avatar
Thanks all. Might be simpler and cheaper to get remans from NAPA.
Old May 10, 2009 | 03:42 PM
ahickman's Avatar
Bought the reman calipers from NAPA and all is good! Thanks.
Old May 10, 2009 | 03:48 PM
abecedarian's Avatar
YAY!!!
On our trucks the caliper is mounted and the pistons float. Many vehicles have only one set of pistons (or even one piston) and the caliper slides (a.k.a. "floating caliper") to bring the outer pad in to the disc.
Old May 10, 2009 | 03:53 PM
iamsuperbleeder's Avatar
yep yep, the pads "float" on the 2 pins spanning the gap in the caliper (the ones that hold the pads in)
be sure to replace those 2 pins too, although new calipers should come with them
Old May 10, 2009 | 03:58 PM
And properly lube the pins with an appropriate anti-sieze lube.
88sasturbotoy
Jan 30, 2026 01:57 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
