Should my t-chain guides look like this?
Old Jan 3, 2025 | 11:31 AM
JaredL's Avatar
1993 Truck 4x4 22re Manual 187,000 miles
I'm tracking down a mysterious an oil disappearance in my truck and I pulled the plugs (which all look great) and decided to adjust the valves and see if anything was wonky there - just the exhaust ones were tight so I adjusted those. I also noticed that the timing chain guides (which have about 80k miles and are metal backed) are being worn into which I know is fine but I thought I would ask if this amount of wear is normal. Thanks!
Old Jan 5, 2025 | 06:35 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Just a guess, but that guide looks pretty thick.
iirc, the oem guides use shoulder bolts, and even after torqued it allows some lateral movement of the guide.
I think the aftermarket metal-backed guides are bolted in place with no movement.
Old Jan 5, 2025 | 07:50 AM
JaredL's Avatar
Good to know. Thanks for confirming.
SomedayJ
Jan 18, 2018 10:31 AM
rustypigeon
Jul 20, 2016 05:36 AM
haystack
Aug 13, 2013 11:05 PM
smackay
Nov 1, 2011 12:40 PM
Badfish740
Oct 26, 2011 06:20 AM
