shifter seat bushing replacement. WOW!
Old Apr 24, 2009 | 04:45 PM
Gizler00's Avatar
I just did mine today. Took about 10 minutes all together. My old shifter seat was all in pieces. I had to pick it out. I can def. really notice a difference in the shifting. Really easy mod
Old Apr 24, 2009 | 05:20 PM
drew303's Avatar
could depend on the transmission... well obviously it does if you're able to do this in 10 minutes.
I have the G52. I dont know what was in my brothers former 85 or our 2wd 87 but they all had the cup with spring in it you have to push and turn. The T-case shifter is much easier to take out =P
Old Apr 24, 2009 | 05:33 PM
lilgreg46's Avatar
I know what he is talking about. He has the W56 trans. With the shifter boot up there is a cup thet as around the stick. Push it down with both of your thumbs and turn it about 20deg or so to the left and it will pop up. Then pull the shifter out!
Old Apr 25, 2009 | 10:53 AM
awareness's Avatar
I would like to order both pieces for my shifter (and also my transfer case shifter too?) but the shipping I was quoted to Canada was over $40US. Seem's pretty pricey for $17 worth of parts.
Old Apr 25, 2009 | 02:39 PM
  #25
Jay351's Avatar
order other parts at the same time like a 54 mm socket!
Old Jul 1, 2009 | 03:29 PM
  #26
TobaYota's Avatar
Originally Posted by Junkers88
To pull the shifter all you need is a cordless drill with an apex in it.
1) Pull the plastic piece around the shifters off.
2) Pull the 6 screws that hold the shift boot and boot retaining plate on the tranny hump.
3) Pull the shift knobs off.
4) Slide the shift boot up and off of the shifters.
5) Pull the 4 bolts that hold the shifter into the top of the tranny.
6) Pull the shifter.
How do you get the two bolts at the front of the shifter plate out, I don't have enough room to get in there....
I was thinking of cutting another access panel.
Old Jul 1, 2009 | 03:47 PM
  #27
Tubbyfatty's Avatar
Have you all seen the shift knobs from MC? I just found one for the tranny, looks really cool, Im thinkin about getting it.
Hey TobaYota - you might have to remove that piece in front of it. Its like a little pocket thing. Its below the ashtray. Wait im talking about the wrong thing. Are you sure you have to do the 4 bolts on top of the tranny? I thought you just throw it in like the video on MCs site...?
Old Jul 1, 2009 | 08:50 PM
  #28
TobaYota's Avatar
Yeah, I am more interested in changing the gasket underneath the shifter plate because I got oil leaking like a bugger. The two bolts at the front of that plate I can't get a socket on, or turn a wrench. I am thinking I will drill two access holes under the carpet and just cover it with sheetmetal after.
Old Jul 2, 2009 | 02:28 AM
  #29
TNRabbit's Avatar
All you have to do is put an impact wrench on the crossmember bolts (PB Blaster first!) and drop the tranny down about 1 inch, then you can get to the bolts. Just don't do like I did & drive it like that dangling from the bolts for 150 miles!
Old Jul 2, 2009 | 04:46 AM
  #30
TobaYota's Avatar
Good idea thanks. I'll try that.
Old Jul 27, 2009 | 07:55 AM
  #31
cpring's Avatar
just pulled out my shifter and sure enough the upper bushing had didintegrated. went to local toyota dealership with shifter in hand . Parts guy had part # for lower bushing but nothing on upper - said I would have to order complete shift assembly.
Old Jul 27, 2009 | 08:05 AM
  #32
cpring's Avatar
just got back from dealership and they couldn't find a part number for the upper seat/bushing on my shifter- said I would have to buy complete assembly
Old Jul 27, 2009 | 08:32 AM
  #33
Junkers88's Avatar
Did you happen to read the entire thread? If so then you can probably go to Marlin Crawler (online) and order the bushings.
Old Jul 28, 2009 | 08:25 AM
  #34
mrddk92's Avatar
Sounds like he didn't read any of it lol. Or maybe just reaffirming the term "stealership". Haha. Well mine are on order, can't wait
aowRS
Sep 13, 2017 08:22 AM
longbed
Sep 16, 2015 10:35 AM
ac7822
Sep 12, 2015 06:57 PM
Pocoyota
Sep 8, 2015 02:41 PM
eggens
Sep 5, 2015 12:16 AM
