Shackle or blocks?
Old Aug 23, 2009 | 06:43 PM
Hayes's Avatar
x(whatever number we're on), get lift springs, or get an AAL. I had an AAL on my first truck and it pick the back end up to stock height and wasn't that much rougher.
Old Aug 23, 2009 | 06:45 PM
ovrrdrive's Avatar
You're not going to find a rear shackle that will fix your sag and give you 4" of lift. If your springs are worn out you'll need a 15" shackle to accomplish that. that would not only throw your entire rear suspension out of whack, it would also be tippy and unstable.
For what you want new springs are the only way to go...
Old Aug 23, 2009 | 07:28 PM
MuddinRI's Avatar
Ok got it new springs for sure maybe shackle too. What is an AAL?
Old Aug 23, 2009 | 07:36 PM
desertcamper67's Avatar
You definately don't want a shackle long enough to get your height back to stock or lifted. As said before, way too tippy and unstable.
Also you don't need a shackle with the brace in the center. All that does is cause your spring bushings to wear out faster, especially if you off road it much. A good quality, thick walled shackle will be your best bet.
x2 on replacing rear springs.
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
moparbay
Oct 6, 2015 09:24 AM
_Nicco_
Sep 21, 2015 03:06 PM
viesail
Sep 5, 2015 04:23 AM
