Running rough under load
Old Feb 5, 2013 | 05:04 PM
twr0110's Avatar
Have replaced wires,plugs,cap and rotor. New TPS.O2 sensor. Idle is ok. Cannot set timing correctly, runs worse. Anything past partial throttle doesn't want to run unless you back off or floor it. 2 days in local shop, they don't have a clue. 89 toyota dlx 4x4. 22 re
Old Feb 5, 2013 | 05:26 PM
bone collector's Avatar
First off...what motor and truck?? second... why cant you set the timing correctly?
Old Feb 5, 2013 | 05:57 PM
twr0110's Avatar
Sorry. 89 toyota dlx 22 re. When the timing is set correctly won't stay running
Old Feb 5, 2013 | 05:59 PM
twr0110's Avatar
Also a 4x3
Old Feb 5, 2013 | 06:03 PM
4x3??? lol anywho... at what degree is it set when it does stay running??? any codes??
Old Feb 5, 2013 | 06:08 PM
BamaYota1's Avatar
Why was it in the shop in the first place? Did the problem start out of the blue?
Old Feb 5, 2013 | 07:22 PM
twr0110's Avatar
Set to spec I assume. Went into shop because of this issue. Started about a month ago and got progressively worse.
Old Feb 5, 2013 | 07:25 PM
twr0110's Avatar
Went into shop for this issue. This has been a project truck for me and my dad. We have slowly replaced its over time. Really came out of nowhere. We have tried everything we knew, not that we know a lot. So we took to a friends shop
Old Feb 5, 2013 | 07:28 PM
twr0110's Avatar
The shop didn't tell us if there where any codes. They checked some things. Replaced the TPS that I put in and that didn't do anything either. They told us to take it to toyota.
Old Feb 6, 2013 | 02:47 AM
My guess is you have a vacuum leak somewhere. or a faulty afm, or an air idle control valve. it could be a lot of things. check for codes and start from there. Get the truck home, download a fsm (search for one on this site) then start going over the truck. Welcome to the "project" part of owning a project truck... lol
Old Feb 6, 2013 | 06:46 AM
twr0110's Avatar
Thanks for your input. At dealer now for a diag. And then I will go from there
Old Feb 6, 2013 | 04:40 PM
ummmm... question... Why are you on here asking for help with diagnosis if your just going to move your truck from shop to shop??? Just curious.....
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
chukarhunt
Dec 8, 2019 11:39 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
