Runnin Hot(er) than normal.
Old May 14, 2007 | 09:51 AM
SwampThing's Avatar
Well, ever since I've had my truck, unless I'm beatin it like a redheaded stepchild, the temp gauge would NEVER go above 1/4 up the termostat. Well last night I was just drivin back home cruisin about 70 for a good 20 minutes or so, and when I looked down before I got off the highway the tempgauge read at a hair under 3/4 the way to the top. Fluids were ok, and it ran fine other than a really wierd idle. When at a stop the rpm's would rise to ~1500 then fall off to round 800 then rise back up again to 1500 and do the same thing over and over again. Noticed the wierd idling when I noticed it was runner alot hotter than normal.
It's kinda got me stumped... Any thoughts?
Old May 14, 2007 | 09:55 AM
Elton's Avatar
t-stat is done
Old May 14, 2007 | 10:07 AM
SwampThing's Avatar
Would the t-stat givin up the ghost cause the idle issues?
Old May 14, 2007 | 10:12 AM
4Crawler's Avatar
Idle speed could just be too high and you are hitting the ECU fuel cutout when the brakes are on:
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
Old May 14, 2007 | 11:38 AM
SwampThing's Avatar
Well I did adjust the idle up a little bit because of the exact same thing. When braking from a good speed (50-60+), my truck would die out just before you came to a complete stop because of the fuel cutout. Guess I've just got to tinker with the screw to find a happy medium?
But... I adjusted up months ago, and this up and down rpm change at a stop has started just when my truck "seems" to be runnin hot. Caint help but think it's cause by that instead of coincidentally being something else happening at the same time. Dunno though, I'll try replacing the t-stat and see if it makes a difference! Thanks yall.
Old May 14, 2007 | 11:53 AM
neilan's Avatar
do yourself a favor and get a aftermarket temp gauge that reads degrees the stock ones suck
zombie_barbarossa
Oct 2, 2015 10:54 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
dbollier123
Sep 29, 2015 05:23 PM
JPV
Sep 28, 2015 03:15 PM
taraf
Sep 25, 2015 02:57 PM
