runner runnimng poorly after eng swap
Old Dec 22, 2016 | 02:20 PM
bro-runner's Avatar
runner running poorly after eng swap
hey hey, new guy here
swapped an engine recently. I drove the good runner before engine purchase, and it ran great.
after swap I cant get her running right...and could use sum help
1995 3.0 dropped into a 1994 (3.0 had bad head gasket)
all went well install wise...starts immediatly
but after a lil warm up ...a min or two, engine begins surging or pulsing. stays running tho.
it then wont take throttle over 1500 rpm....just goes flat
swapped a lot of obvious things and looked for leaks....but my pea sized brain isnt overcoming the issue
any and all ideas welcome.....
thx
bro out
Old Dec 22, 2016 | 04:33 PM
robertd33's Avatar
welcome bro
i would re-check the enormous amount of vacuum lines on the passenger side. and the right side, too.
3vze has tons of opportunity for vacuum leaks due to all the pair/egr/vsv we have.
Old Dec 23, 2016 | 11:07 AM
bro-runner's Avatar
thx rtd33...
vac lines suck indeed....perhaps it is possible that a line would prevent proper acceleration
and....surging.
be nice to have a 2nd runner to view lines and proper plug ins.
am much better with visual than schematics!
Old Dec 23, 2016 | 11:21 AM
RBX's Avatar
RBX
You don't need a second vehicle, you just need google...
Type this in the Googles...
3vz vacuum line
Old Dec 23, 2016 | 11:25 AM
Schnayke's Avatar
coolant needs burped maybe?
Old Dec 23, 2016 | 03:24 PM
robertd33's Avatar
Old Dec 23, 2016 | 09:13 PM
bro-runner's Avatar
Very awesome I appreciate the input guys...and that picture is worth a thousand words
Old Dec 24, 2016 | 02:33 PM
wyoming9's Avatar
Red face
In the engine swap did you change the fuel filter ??
Lots of times moving things around knocks dirt loose.
Old Dec 25, 2016 | 05:51 AM
bro-runner's Avatar
Fool filter was changed.....the
And I wonder if there isn't some vacuum device that has power over engines ability to rev
