RR crossing conked out my 86 4runner
Old Jun 24, 2018 | 05:22 PM
Bluduck's Avatar
Hit a surprise RR crossing about 30mph faster than I should have. Stalled out and sputters when I turn it over, but won't run more than a second or so. I checked all the wires and plugs I can get to on a hot engine roadside. Anyone have any ideas?
Old Jun 24, 2018 | 05:58 PM
Terrys87's Avatar
Did you knock the cable loose from your air box? Any loose hoses that could cause a vacuum leak?
Old Jun 24, 2018 | 06:07 PM
Bluduck's Avatar
The airbox looks all good, can't find anything loose, unplugged.
RAD4Runner's Avatar
Like Terry says. Getting combustion while cranking but shutting down when IGN key is released usually has something to do with the circuit opening relay and the AFM flap. Here's how it works:
https://www.yotatech.com/forums/f116.../#post52387681
When engine cools down. Inspect all connections again. Pls see signature.
Old Jun 24, 2018 | 06:15 PM
Bluduck's Avatar
Got a tow on the way, this should be useful once I get it home. Thanks!
Old Jun 24, 2018 | 09:46 PM
wyoming9's Avatar
Red face
I wonder if the landing caused the Circuit opening relay to be damaged after all it is getting up there in age .
Then it could be almost anything fuel related .
Old Jun 24, 2018 | 11:25 PM
RAD4Runner's Avatar
I'm betting on loose wiring/connections.
Old Jun 25, 2018 | 01:20 PM
Discombobulated's Avatar
Sooooo what speed should you have hit it at?
Old Jun 25, 2018 | 02:45 PM
thefishguy77's Avatar
First real post of the thread.
Old Jun 26, 2018 | 01:42 PM
jakey poo's Avatar
I'm hoping 60mph, and he took it Dukes of Hazzard style
Old Jun 27, 2018 | 11:30 AM
Bluduck's Avatar
Got down to around 45 when I hit the tracks, but I did catch some respectable air. 😂
Old Jul 1, 2018 | 07:20 AM
All 4 off the ground?
Old Jul 1, 2018 | 03:47 PM
Nate Allan's Avatar
I assume this is a FE motor? Check your tab or spade style terminal connections at the injections this has more common than not been an ongoing issue.
Old Jul 2, 2018 | 05:33 PM
Bluduck's Avatar
Need more specifics. I put a new COV in and it still just turns over, without starting. Yes, all 4in the air.
thowho1985
19
Jun 17, 2005 09:14 PM
FunRunner01
Jun 22, 2004 07:31 AM
Hyperlite
Aug 10, 2003 09:24 AM
