Rough idle when hot
Old Apr 4, 2010 | 01:41 PM
Culpeper's Avatar
Rough idle when hot
I've got a rough idle when it is hot outside after driving it around a while in town. Today it really got rough. No diagnostic code. No check engine light. I reset the ECU by pulling the EFI fuse and it started running good again. Could this be my ECU is going bad? I can't figure it out. It's a 1990 V6 4runner.
Old Apr 5, 2010 | 11:46 AM
Culpeper's Avatar
bump. Has anybody seen a problem like this?
Old Apr 5, 2010 | 03:59 PM
truckmike26's Avatar
I've had a hot re-start rough idle forever it seems on the 3.0L. It happens just after starting a hot engine that's been soaking in the heat. Driving normally or reving it for a bit makes it go away. Is this similar to what you have going on?
Old Apr 5, 2010 | 06:47 PM
Culpeper's Avatar
Exactly as you described! The other day was worse than usual. I noticed it was also running rich so I adjusted that and reset the ECU. Today was a hot day and it ran a lot better but I can still tell it wants to act up a little. I started noticing this at least last summer if not before.
Old May 15, 2010 | 03:05 PM
I should add that, when it happens, there is no visible smoke whatsoever coming from the tailpipe. I'm inclined to think it's a temporary vacuum leak from somewhere or a sticking vacuum valve.
Old May 15, 2010 | 07:30 PM
Culpeper's Avatar
I've noticed a lot of pressure in the gas tank. I don't make the cap air tight and the problem vanishes. But since I posted the problem I really hadn't seen much hot weather lately. I'm going to try and figure it out of it continues.
Old May 16, 2010 | 05:27 PM
TylerH's Avatar
Try replacing the ECT switch that goes to the ECU. It should be the coolant temp sensor with the plugend.... not one wire.
Hope this helps....
Old May 17, 2010 | 06:56 AM
Tanker5503's Avatar
I also have been having this same problem for awhile i just turned the idle screw up as a temporary fix but can feel it not idling right still but it inst almost dieing on me as well. driving for 1-2 min would make it go away for me as well. No check engine light
Old May 17, 2010 | 07:09 AM
Kiroshu's Avatar
Start looking at Distributor and coil components. Air filter dirty? Timing set correctly with Idle? If you have to adavance timing and low idle on the 3.0 you may have these probs as well.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
1992pickupSr5
May 9, 2019 08:44 AM
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
