rough idle, rougher when cold, and popping during deceleration
ok before i get into this the truck i'm talking about is my 86 turbo pickup 22rtec 4x4 all stock besides an intake, exhaust, boost controller set at 10 psi, and greddy type s bov. ok heres the problem. i'll start my truck in the morning/when its cold and the truck never starts on the 1st crack. i gotta crank it, apply throttle then it will start. then when it finally starts it idles really rough and will even die certain times. if i get on the throttle it will sound like its running on 3 cylinders until warm. for now i have the idle set so it idles around 1000-1200 cold warm and 800 cold. then when it gets warmed up finally the motor rocks alot. this part doesn't bother me that much but i just thought id mention it. and it pops like a mother when i'm off the throttle. im leaning towards blown hg but not sure. any suggestions/past experience would be helpful. thanks in advance.
Figure out which cylinder first. Lots of ways to do that.. I use leather gloves, and don't touch any metal... pull one cable at a time to find the bad one.
The popping when decelerating is caused by a faulty/misadjusted dashpot. It wouldn't effect the engine performance, so that ain't likely the only problem. It is an emmissions device, and it can be compensated for by releasing the throttle more slowly when decelerating. It's purpose is to do just that, if you release the accelerator suddenly, the dashpot holds the throttle plate open temporarily, preventing that popping sound and lowering the emmission of one of them greenhouse gasses, I don't remember which.
Would that dashot dealy be a possible reason for some slight "popping" at idle? Mine seems to run nicley, but at idle is moves in about a 50-75RPM range at idle (just enough to hear), and pops a tiny bit.
ok so i changed the spark plugs and same thing. im gonna try and comp check the motor we'll see what happens.
but say the timing is off by a tooth or so... would it still idle good when warm? im not quite aquinted with toyotas but on other cars ive worked on if its off by even 1 tooth it runs like ☺☺☺☺ all around.
Not to suggest that being off a tooth is the probem, but the short answer is yes according to others on this forum. As I recall it shows up as a problem in timing adjust, but will run fine at idle. I'm sure you can find the references with a search.
montanatruck
Feb 26, 2017 07:07 AM
