Roof Rack 86 4runner
Old 12-20-2006, 04:51 AM
GrimReaper's Avatar
Just a FYI for future. Late 80''s Jeep Cherokee have a REALLY long roof rack. It starts about 8 inch from the windshield and runs all the way to the gate. there are two styles. One is a flat C channel and that's the one you want. Its nearly identical to the racks they sell at Leer stores.
it is similar to this but the track is a little lower profile.
http://www.a1-autoracks.com/proline-...age-racks.html the tracks are almost 7ft long on the Cherokee. If you are junkyard them bring torx bits. Some years are torx some Philips.
I have used these racks on a couple of vehicles including my suburban with Thread inserts/ rivet nuts. Worked very well. On the fiberglass top you might try using "well plugs". Its a rubber gr omit of sorts with a thread piece in it. As you tighten it pulls the threaded part up and expands the rubber to fill the hole. actually pretty strong set up. GM used them for years to hold mirrors on trucks. make 73-87. Might be able to get them at Leer as well.
Old 12-20-2006, 01:21 PM
4Rocker's Avatar
$130+ for a light bar? After seeing how they attach, I bet i could make my own for a hell of a lot less, and it would sit lower too.
Old 12-20-2006, 05:00 PM
ewong's Avatar
Why I cant use the short roof line extender...
Old 12-20-2006, 07:03 PM
vmax84's Avatar
Man, keep that pretty red 4runner out of the salt!!! Please.
vmax84
Old 12-21-2006, 03:44 AM
  #25
Numbchux's Avatar
yep. no way would I buy one new...but I see them for ~$100 on ebay. and I bet if you were patient, you could find a used one for much less.
Old 12-21-2006, 06:42 AM
  #26
4Rocker's Avatar
I think sometime this spring I might get some 2"x1" C-channel and some 1/4" plate steel for the ends and just weld one up. After looking around at pics of the KC bar, i think it would be possible to duplicate their mounting system with something fabricated. I just dont like how tall that bar stands up above the roof
Old 01-03-2007, 07:16 PM
  #27
PeanutRanger's Avatar
do 1st gen runners have raingutters?
Old 01-04-2007, 07:35 AM
  #28
ewong's Avatar
YES
over the doors
There is a "fake" raingutter over the slider windows on the cap, but its fiberglass and not very strong.
Old 01-04-2007, 08:01 AM
  #29
amgraham's Avatar
It's pretty easy to put those bolt on gutter mounts in the back because, like ewong said, those fiberglass ones over the rear windows are not strong enough.
I'm probably just going to bolt a rack directly too the top of mine. I don't like how most of them sit up so high.
BushPig
10-29-2022 06:26 AM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: Roof Rack 86 4runner
