RockAuto Knock Sensors?
Old Jun 5, 2020 | 05:40 PM
Amos Elam's Avatar
Browsing rockauto for knock sensors, are the choices they have on there a good replacement? Ultra-Power, Beck/Arnley, WVE, Standard Motor Products, NTK? Any of these acceptable replacements? I actually broke the plastic on top of the existing knock sensor
Old Jun 5, 2020 | 06:29 PM
arlindsay1992's Avatar
What engine? I'd recommend OEM only, especially for the 3.0 V6. There are dozens of nightmare threads from people who tried to save a few bucks and ended up paying twice.
Old Jun 5, 2020 | 06:38 PM
Amos Elam's Avatar
yea its a 3.0. Its hard to justify $250 for a split second mistake. The metal connector is still in place, wondering if I could solder the connector wire on at this point
Old Jun 5, 2020 | 08:27 PM
stefanc's Avatar
OEM Sensor. Bought and installed 6 months ago. Worked like a charm
https://www.ebay.com/itm/OEM-DENSO-K...72.m2749.l2649
Old Jun 6, 2020 | 07:31 AM
scope103's Avatar
That eBay seller states that the sensor you're using is "unbranded." So I don't think I could call it made by the "Original Equipment Manufacturer." Maybe what the seller meant was that it was OEM "like," as contrasted with a "universal" replacement.
But a report of personal experience counts for a lot, and 6 months seems a fair test.
Old Jun 6, 2020 | 08:56 AM
old87yota's Avatar
Wow, that $11.88 eBay sensor seems awfully cheap, considering that a known OEM one from Toyota is $277.81 MSRP.
That is like buying a new 2020 Toyota Land Cruiser for a few thousand dollars. Something seems fishy......
Old Jun 6, 2020 | 09:17 AM
stefanc's Avatar
hmm perhaps the listing changed since I bought it? Mine arrived in OEM packaging with the OEM part number.
Either way, would not recommend an after market part as that what I ended up having to replace...
(Pic as it arrived)
https://imgur.com/qS96Ya4
Old Jun 6, 2020 | 09:21 AM
scope103's Avatar
Well, I'm pretty sure Toyota never made their own knock sensors. As best I can tell the OEM for our knock sensors was Denso. It appears Denso doesn't make knock sensors anymore. https://densoautoparts.com/ So to get a knock sensor, we'll have to rely on NOS, or aftermarket. This seller
Amazon Amazon
claims to be selling genuine Denso branded knock sensors for $40. Amos Elam's original question was whether anyone here had experience with certain aftermarket knock sensors. stefanc provided his success story, as fishy as the seller's claim of "OEM" may be.
It does raise the question of who makes the $200 knock sensor sold today by Toyota dealers. https://parts.lakelandtoyota.com/p/T...961550010.html
Old Jun 6, 2020 | 12:02 PM
amamike91's Avatar
My knock sensor went out. thought i would try the rock auto sensor. it did not work. So i bought one from Toyota, cost me around 180 delivered. Fixed. Cheap don't always work.
Old Jun 7, 2020 | 06:20 AM
Andrew Parker's Avatar
How bad is the plastic busted? Perhaps you can fix it with J & B weld epoxy adhesive? The sensor is a piezo electric crystal inside which produces a voltage signal to the ECM when the engine is knocking. If the electrical connection is still intact I would try this approach if you are willing to risk the assembly disassembly time to install it again?...
Old Jun 8, 2020 | 04:32 PM
Amos Elam's Avatar
This is the old one. I’m going to try to find a used on online
zchead
Nov 27, 2015 11:29 AM
frankenstang91
Dec 28, 2014 01:15 AM
Buggz_14
May 29, 2013 09:03 PM
gerhardf
Apr 13, 2006 05:52 PM
