Removing rear heater?
Old Jul 4, 2011 | 04:09 PM
  #41
mlrunner95's Avatar
Originally Posted by 95 4Runnin
did you say you had a 95 4runner? because my dont have a rear heater
I think its just the limiteds that have it. I dont mind the center consoles in the 4runners like yours but I wanted to try something different. If I get tired of the ammo can, I will most likely try to get my hands on a non-heater center console to replace it with.
Originally Posted by 93YotaGuy
Now you'll just have to put the key under the truck where it isn't easily accessible and if you ever get pulled over and they want to search the crate they will need a warrant! Hahah
Haha I will keep that in mind if I ever end up working for the cartels.
To rockingthe2, I will try to get some pics this week for you. Like Blue Steel said, its pretty simple and if you are thinking about doing it, I say go for it. Totally worth it in my eyes.
Time to get the tri tip on the grill . Happy Independence day to the American yotatechians. Be safe.
Old Jul 5, 2011 | 11:02 AM
  #42
vasinvictor's Avatar
My '92, not limited, has one. You have given me the info I need to remove that sucker. It's doesn't work anyway...
OH, and your interior is pretty nice, jealous.
Old Jul 9, 2011 | 09:19 PM
  #43
mlrunner95's Avatar
Thanks! haha
Here is a pic of the bypass once its all hooked up for whoever wants it.
Old Jul 10, 2011 | 09:19 AM
  #44
WartHoggRunner's Avatar
mlrunner95 - That is pretty cool, think I might have to do that as well, it would match my already army green 4runner nicely.
Old Aug 29, 2011 | 07:04 PM
  #45
I started working on mine today but I only have the small cans or a 30mm which is pretty big, it fits in between the seats but takes some muscle to get it in. So ill finish once i can find a 40mm like yours. I did get the heater and everything else out and hoses re-routed, hole is still in the floor for the moment.
Old Aug 30, 2011 | 05:44 AM
  #46
Stuwy123's Avatar
You guys do know that the SR5 Pickups had a double lid center console, right?
Instead of rear heat under the center console, it's all storage.
So instead of using an ugly-as-sin ammo can, how about making it look factory?
As for running a bypass, why not just use the plumbing from the pickups? They didn't have rear heat. Just one hose from the engine coolant to the switching valve and then to the heater core in the dash, then back out into the coolant system.
Spend a little time in the junkyard and you'll be surprised at what you can cross-over between the 4Runner and Pickup.
Old Aug 30, 2011 | 01:03 PM
  #47
mlrunner95's Avatar
For the record, I prefer the look of the ammo can over the factory center console. But your right, the two tier center console would work just fine.
Old Feb 5, 2013 | 08:07 PM
  #48
a51young's Avatar
Great write up! I am hoping to get something like this done this weekend! Is yours still holding up nicely?
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
msane99
Jul 17, 2015 10:13 AM
the1998sr5
Jul 16, 2015 06:20 AM
icentropy
Jul 14, 2015 10:23 AM
