Removing oil pan?
Old Jun 8, 2008 | 01:54 PM
91Toyota's Avatar
Removing oil pan?
Seems simple right. Got the bolts off. Its loose, then I remove the friggin' sway bar...now it STILL won't come out. I've been trying to tackle this POS for the last 2 hours...I could remove my whole engine faster than that...lol.
So, how do you remove it? Am I supposed to remove all the steering components to then take it off? Am I supposed to loosen the engine then somehow jack it up? I seriously don't know.
PLEASE HELP!!! Thanks!!!
Old Jun 8, 2008 | 01:55 PM
abecedarian's Avatar
drop the crossmember between the front control arms ... just a few bolts
Old Jun 8, 2008 | 01:57 PM
91Toyota's Avatar
Already did that...
Shall I take a pic
Old Jun 8, 2008 | 02:02 PM
sure.
but that's all did on my 91- drop the sway and xmember
there's a baffle in the pan too so you have to make sure to not catch the pickup in it.
drop the deep side of the pan straight down then work the pan out.
Old Jun 8, 2008 | 02:13 PM
91Toyota's Avatar
Ah, give me a minute and I'll upload the pics...they are right now on photobucket. I thought thats what you were supposed to do too but its just not budging at all...lol
Old Jun 8, 2008 | 02:14 PM
T-1000's Avatar
Sounds like it's time to bust out the screwdriver/chisel and mallet.
Tip: Radiator + hammer = lots of dents, no movement
Old Jun 8, 2008 | 02:15 PM
not budging? you mean it won't come off the engine block?
yep- screwdriver and mallet time.
91Toyota's Avatar
Old Jun 8, 2008 | 02:16 PM
91Toyota's Avatar
No, it is...I just can't get it out so I can see inside. I can't get that piston out unless I move this big hunk of metal out of the way...lol
Old Jun 8, 2008 | 02:17 PM
91Toyota's Avatar
Sorry for the horrible pics...lol
okay, unbolt the idler arm on the passengers side of the frame so the steering linkage will drop down low enough to slide the pan past.
*I forgot I had to do that on mine too.
Old Jun 8, 2008 | 02:18 PM
91Toyota's Avatar
Hold on...is this the idler arm? I'm taking a pic and upoading it...just a minute...lol
Old Jun 8, 2008 | 02:21 PM
91Toyota's Avatar
Okay I literally ran...lol.
Is this it...
Old Jun 8, 2008 | 02:24 PM
yep... three bolts at the front end of the arm that hold the pivot to the frame
91Toyota's Avatar
I'll just remove it anyway...lol
Old Jun 8, 2008 | 02:25 PM
91Toyota's Avatar
Alright...thanks! I'll get back to work now...so far this has been the hardest thing to do...LOL
Old Jun 8, 2008 | 02:26 PM
just wait til you hit puberty
Old Jun 8, 2008 | 02:42 PM
91Toyota's Avatar
lol
Anyway, the top bolt is a beotch to get off. I've hit a wrench with a hammer like 100 times and it's moved very little...lol. My cheater bar won't fit over it either. I have some penetrating oil soaking it right now...hopefully it will be easier to remove
Back to work I go!!!
Old Jun 8, 2008 | 02:52 PM
Luvmeye22re's Avatar
Heat that bolt up with a MAPP gas torch for a minute and it'll come out
Old Jun 8, 2008 | 02:56 PM
91Toyota's Avatar
That did the trick! Thanks bud!
What is your name anyway? lol
Mine is Trevor...if you care at all
