Removing front sway bar for desert running
Old Mar 10, 2009 | 10:38 PM
ericyota's Avatar
Anyone have any thoughts regarding front sway bars and removing them for desert running. none of this 4x4 slow rock crawling stuff(not hating though, i mean come on, who doesnt like rock crawling?!) i got a 2wd 88 w/ 3 inch body lift.
Old Mar 10, 2009 | 11:17 PM
space-junk's Avatar
there are numerous threads out there concerning this issue...
IIRC, the consensus was that you get waaaay more flex from removing it... but you lose some of your on road manners...
do a search on here and you will find the info you need...
good luck...
Old Mar 10, 2009 | 11:38 PM
abecedarian's Avatar
It's 2wd so removing the sway bar won't affect much. You may get more lean but...
... you didn't say if you have any sort of lift or travel kit intalled.
We have a 91 2wd with Fabtech 3.5" lift and uprated torsion bars and have the sway bar in but there really wasn't any noticible difference between having the bar in or out.
Old Mar 10, 2009 | 11:55 PM
Matt16's Avatar
good luck...
I nearly said the same thing, but he wants to know about dessert running.
The nearest dessert is far far away, so take my advice with a grain of salt, but I do frequently drive faster than most on gravel roads. If your doing a lot of turning (includes donuts) leave it on for sure, my 2wd had lots of body roll as is.
If you're doing high speed straight line stuff, then maybe take it off, but I didn't notice an improvement in ride at higher speeds without the sway bar myself.
I definitely leave mine on on my 4wd 4Runner until I'm doing slow speed stuff, but my truck is such a different kettle of fish compared to yours. Maybe look on TTORA, as it seems to be a little more dessert-oriented.
voiddweller
19
May 2, 2016 09:10 PM
Niameyrider
Jun 25, 2015 05:50 AM
Luke
Jun 12, 2002 10:58 PM
Luke
Jun 10, 2002 10:07 AM
