Rear anti sway bar on a 2nd Gen
Hi Guys
Can any one tell me is it safe to ride around for a couple of days with my rear anti sway bar removed?
I had to fit a new bracket today that holds the swaybar to the axle and managed to snap the bolts in thier holes
so I gotta have them drilled out and re tapped. What a bummer
Anyways I removed the whole bar and was wondering if this would be ok for a while
Any advice appreciated
Cheers
Luke
so I gotta have them drilled out and re tapped. What a bummer Anyways I removed the whole bar and was wondering if this would be ok for a while
Cheers
Luke
You should be fine. Just take it easy around the turns until you get used to it. I drove with my addco front bar installed and no rear bar for a day while waiting for a bracket to arrive. Around fast turns it can be scary b/c the rear body rolls so much, but with reduced speed it is no problem.
When you remove the broken bolt, remember that the rear sway bar bracket bolts get torqued to only 14ft/lbs (on my 1999 at least).
Thanks for the advice guys! Hey Adam I took my truck out last night with the bar removed to see if there was more body roll and there didnt seem to be any, so I guess Im good for a couple of days.
Cheers
Luke
Cheers
Luke
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
Steezy96yota
Jul 6, 2015 10:00 AM
Vargntucson
Jul 4, 2015 12:15 PM
