Removing engine
Old Feb 1, 2020 | 06:13 PM
87yotasr5's Avatar
Removing engine
I have a 22RE 4wd with a standard shift 5 speed transmission and going to pull the engine and rebuild. Is it possible to remove engine without dropping transmission first? A
nd if so how much harder will it make it if leaving trans in place?
Old Feb 1, 2020 | 10:35 PM
2ToyGuy's Avatar
According to the FSM, no. You pull out the engine and transmission as a unit, and then remove the trans, once you have the pair of them all the way out.
You just have to angle the engine/trans correctly to be able to lift and tip then slide forward and up at the same time until it all comes out.
Does this help?
Pat☺
Old Feb 2, 2020 | 02:06 AM
wallytoo's Avatar
it is possible. i’ve done it on each of my ‘87 4runners. once to replace a clutch, and once to rebuild a 22re with a blown headgasket. i cannot say how different it is vs removing the transmission, because i have never used that method for removing the engine.
Old Feb 2, 2020 | 04:03 AM
13Swords's Avatar
5 Year Member
If you're rebuilding the engine I say just go ahead & pull the trans with it. That way it will be easier to clean up the trans too & get some new trans mounts in it, new input & output seals if needed, etc.
Old Feb 3, 2020 | 01:55 PM
swampedout's Avatar
5 Year Member
+1 for pulling the trans.
Old Feb 4, 2020 | 10:50 AM
Co_94_PU's Avatar
1: very possible. Use your engine leveler, a friend would be handy also. You might need to air down the tires some for clearance depending on you crank and rigging.
2: not impossible, but it's much more straight forward when you have the better access on the floor.
Old Feb 4, 2020 | 11:41 AM
arlindsay1992's Avatar
If the transmission is fine I would definitely not recommend removing it. It's not difficult at all to remove the engine with the transmission in place. I use a ratchet strap looped between the frame rails under the transmission to support the front of the transmission with the engine out.
Old Feb 4, 2020 | 11:57 AM
swampedout's Avatar
5 Year Member
The most annoying part is getting those top trans bolts. Get a socket swivel adapter to get an angle.
after that it should be straightforward. Less maneuvering than if you pull the trans and motor.
Old Feb 4, 2020 | 01:39 PM
87yotasr5's Avatar
Thanks everyone. I was able to get it out without removing the trans. It was actually pretty simple. Now I just hope I can get everything to line up and go back in as easy once I finish rebuilding
Old Feb 4, 2020 | 01:42 PM
87yotasr5's Avatar
This was one of the better rod bearings. And I was just hoping to replace the timing chain but the motor had other plans
Old Feb 4, 2020 | 01:56 PM
swampedout's Avatar
5 Year Member
Keep us updated. Whatever problems you run into, someone has probably had to deal with the same thing.
you may not have wanted to, but its good youre rebuilding from the bottom up. Get it done now and dont worry in the future
Putting it back together isnt too complicated. Fine tuning the timing is often the tricky part but you can figure it out.
Old Feb 9, 2020 | 08:26 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Chasing the threads on the mounting bolts and holes in the block did help me a bit. I too used the swivel socket for the top two bolts, with about 3+ feet of extensions. Having someone peer down from the top to help the swivel onto the bolts is nice.
You can actually order individual Snap On metric tap and dies from their website. Pretty darn cheap (I'm guessing they did it to help techs replace damaged ones in kits.) I don't recall they charged any shipping, either.
Taiho is/was a bearing supplier for Toyota. You can often find their bearings for the 22r# at a good price. Same with NPR (Nippon Piston Ring Co.) for rings. Pistons, too.
Old Feb 10, 2020 | 09:22 AM
87yotasr5's Avatar
Yea we went with King bearing and Nippon piston/rings
vmax84
Nov 27, 2018 01:14 AM
chop_suey
Aug 22, 2010 01:48 PM
87tonka
Jan 16, 2008 12:35 PM
Cid_4r
Dec 6, 2006 05:19 AM
