Removing Body lift, Factory bolt length?
Old Jun 6, 2008 | 01:14 PM
sleaz22xx's Avatar
I am removing a 3 inch body lift that the previous owner had installed on my 94 4runner. Does anybody know the length and diameter of the body mount bolts that come from the factory.?
I plan to replace with grade 8 bolts and nyloc nuts.
THANKS
94 4runner 4wd A/T 3.0
Old Jun 6, 2008 | 01:45 PM
881stGenRunner's Avatar
just go to advance auto or somewhere similar and buy a polyurethane bushing kit for the body and it will come with everything you need including bolts.
Old Jun 6, 2008 | 01:48 PM
sleaz22xx's Avatar
Thanks, But i think it may be more economical to just get new bolts.
Any body else?
Old Jun 6, 2008 | 01:50 PM
where are you going to get new bushings?
Old Jun 6, 2008 | 01:52 PM
4Crawler's Avatar
Body mount bushing kits typically do not come with new hardware, you re-use the existing bolts:
- http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
For new hardware, just get bolts 3" shorter than what is on there now, typically 3/8" dia., stock is 10mm:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ11
Old Jun 6, 2008 | 01:55 PM
sleaz22xx's Avatar
my dilemma is that i done want to have to remove all the bolts from before i get the new bolts(dont want my body just hangin out)
I have removed the front left bolt, would all the bolts be the same length as this?
Thanks
Old Jun 6, 2008 | 01:58 PM
sleaz22xx's Avatar
The factory busing are still there and in good shape, the body lift mearly sat on top of the factory bushings
Old Jun 6, 2008 | 02:09 PM
gotcha. k. good luuck
Old Jun 6, 2008 | 02:10 PM
sleaz22xx's Avatar
am i to beleive that the bolts at all 8 mounts are the same length
Old Jun 6, 2008 | 02:32 PM
waskillywabbit's Avatar
No.
Old Jun 6, 2008 | 04:08 PM
sleaz22xx's Avatar
bump
1o char
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
