Redneck Engineering question
So, I have an 88 with that dopey half H looking steering wheel. I gotta say, I hate that damn thing!
I'm always beep the horn by accident. Backing up, turning around, etc.
I'm looking for replacement ideas. But, not the typical Grant wheel replacement. I'd love to see the non-traditional versions. Wheels from older cars/trucks, different makers, even homemade, if anyone has done that.
Thanks folks!
Thanks folks!
Anyhoo, "should bolt right up." is exactly what I'm looking for. However, other than other truck wheels, I have not been able to determine which wheels from Toyo cars that will for sure "bolt right up." I thought an 88 MR2 wheel would, but I think it still needs modification.
I think I read once that most Toyota steering wheels use the same spline pattern - so essentially you're open to any Toyota steering wheel. It's common on some of the older Land Cruisers - like if you didn't care for the large diameter of the original and wanted smaller diameter from say a Celica.
I would definitely do some research on the part before you buy anything.
As for the Grant steering wheels I never cared for the aesthetics of one of these, but they are one of the few companies that make removable steering wheel/anti-theft device, so just for that reason alone I would not rule them out as an option for replacing your steering wheel.
For what it's worth, I called my local Toyota parts dealer, and they said that the only direct swap wheel for my 88 would be from an 86-89 4Runner. Which is, of course, the same ugly-ass wheel I already have!
The next time I have both of my steering wheels off, 88 & 90, I'll have to see why/if they really aren't compatible.
Anyhow...it looks like an 88 MR2 wheel would work...maybe? See following thread. http://www.alltracwagon.net/forum/m-1398549428/
I haven't had good luck going into the dealers with a part and saying "I need something like this....". Their system isn't setup to find parts based on specifications or measurements, its setup for application.
Sorry, I don't have an answer or other suggestion for you.
I'll bet all they did was look up the part number for your current steering wheel, then look up all the other applications where that part number was used.
There are also kits for swapping different wheels. but I'm still pretty sure the bore and splines should fit many Toyota wheels, especially if it's from another truck/4runner.
FS[MidAtl]: 1987 SR5 Wheels, Lugnuts, Center Caps
arlindsay1992
Feb 23, 2016 11:36 AM
JCBond
27
Feb 8, 2016 05:00 AM
sharrack
Jan 2, 2016 01:50 PM
sechott
Dec 29, 2015 05:06 AM
