rebuilt motor but no power....help wise ones
Old Jun 29, 2009 | 03:50 PM
yotabiff's Avatar
Ya,if you have the hydraulic tensioner,that could be the problem,mine passed the tests on the FSM so I reused it ,then after I got going was having problems with power under load and TN Rabbit suggested that the timing belt must be off so I tore it down and the marks were ok so I checked the tensioner and it had a very slight seepage of fluid so i changed it out and that did the trick. Not that hard to do since you will probably be going in there to recheck your timing marks
Old Jun 30, 2009 | 03:04 AM
TNRabbit's Avatar
I still say it's your TPS or Knock Sensor. I forget; did you say you get any codes?
Old Jun 30, 2009 | 08:14 AM
flyboi001's Avatar
I originally had a code 72 so I reset it and now I got a code 71. I am going to definitely look at the timing and tensioner. How do you inspect the tps. I need to get ahold that shop manual!
Old Jun 30, 2009 | 08:39 AM
TNRabbit's Avatar
Everything is in the manual; just be sure you pick 3VZE and not 22RE as it's easy to follow the wrong link:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
cars-guy
Aug 16, 2020 06:59 AM
ViperTT
Aug 14, 2015 05:27 AM
adammtb
Jul 27, 2015 11:57 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
