Rear window not working
Old Feb 26, 2007 | 06:55 PM
mch944's Avatar
Angry Rear window not working
I need some help. My rear window in my '89 runner just stopped working, I checked all the bolts on the top making sure they are tight, I checked the for blown fuses, none were brown. I checked to see if there is power at the switch and there wasn't. I checked the wipper for the saftey switch and it was ok. I ran power direct to the motor from my battery and it didn't budge. I don't want to spend money and a new motor if it is a power issue? Please advise.
Old Feb 26, 2007 | 06:59 PM
shantz's Avatar
motor
Old Feb 26, 2007 | 08:33 PM
surfmobile88's Avatar
My rear window wouldn't work due to a bad rear tailgate switch. It failed and defeated the moter as if the tailgate was open even though it wasn't. I just jumped the 2 wires and it worked. There are 5 different switches in that circuit that can defeat the moter. Good Luck
Old Feb 26, 2007 | 08:39 PM
If it's the moter since you ran power direct--you can replace it with any window moter from several years and multiple Toyota models. They're all the same, just get one from a wrecking yard out of a supra, truck etc.
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
