Rear Tranny Output shaft play
Old Sep 19, 2011 | 11:47 AM
peow130's Avatar
Title says it all..
1987 Toyota pickup, 5 speed, 22R.
Got up under the truck because i noticed oil spray off the pinion flange at the transfer case end..
Wiggled the driveshaft, a little bit of play in the output shaft of the tranny..
Is there a bearing or bushing i can replace, or do i need to find a new tranny..
Old Sep 19, 2011 | 11:53 AM
4Crawler's Avatar
Tranny or t-case output? On the t-case output, might be the staked nut has loosened allowing play in the flange. Easy to check and tighten up (to 90 ft.lb. or so). Also a seal there that might be causing the oil leak. If tightening does not work, there is an output shaft bearing in there.
Old Sep 19, 2011 | 11:55 AM
peow130's Avatar
I'll check, but i always aim for the worst case scenario, because thats usually what ends up happening with this truck :/
Old Sep 19, 2011 | 12:07 PM
peow130's Avatar
Day saved, staked nut was loose. Replacing seal while i'm in it.
Thanks, 4crawler. I didn't even think of the staked nut
Old Sep 19, 2011 | 12:09 PM
waskillywabbit's Avatar
That would be the rear tcase output, not your tranny.
Pack some sand in it.
:wabbit2:
Old Sep 21, 2011 | 01:39 PM
peow130's Avatar
:wabbit2:
shoooot. i'll fill it with sawdust, that'll make it quiet
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
madxman21
Jul 9, 2015 10:26 AM
