Rear Tranny Output shaft play
Title says it all..
1987 Toyota pickup, 5 speed, 22R.
Got up under the truck because i noticed oil spray off the pinion flange at the transfer case end..
Wiggled the driveshaft, a little bit of play in the output shaft of the tranny..
Is there a bearing or bushing i can replace, or do i need to find a new tranny..
Tranny or t-case output? On the t-case output, might be the staked nut has loosened allowing play in the flange. Easy to check and tighten up (to 90 ft.lb. or so). Also a seal there that might be causing the oil leak. If tightening does not work, there is an output shaft bearing in there.
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
