Rear end sag '88 4 Runner helper springs
Old Nov 13, 2006 | 06:43 PM
spudrunner's Avatar
Anyone ever tried using these helper springs to lift the rear end? Looking for some advice.
http://www.jcwhitney.com/autoparts/I...D:100000233659
Old Nov 13, 2006 | 06:47 PM
curly_c's Avatar
never seen those in my life. just get some rancho add a leafs and go with those. either way it seems like you will still have to do the same amout of work to put them on so might as well go with something proven
Old Nov 13, 2006 | 07:11 PM
Bear80's Avatar
They are "helpers" for load. They will not add lift or have a noticeable effect the ride. If you sagg in the back get an add a leaf.
Old Nov 17, 2006 | 10:33 AM
Schmeal Hawk's Avatar
I don't know about those things. I seems to me that this product is for a loaded up pickup bed or a heavy trailer. Also if your car is already sagged they may be compressed even when the truck is unloaded when installed. I would stick with a good AAL. I ran 2 different AAL's in my 88 4runner. First i had the pro-comp Aal's, they were way stiff and made the truck sit way high. I changed them to the rancho soft ride AAls and i couldn't be happer.
Old Nov 17, 2006 | 10:47 AM
4Crawler's Avatar
Yes, the Rancho Soft-Ride Add a Leaf kit is good: http://www.gorancho.com/
Or see this option:
http://www.4x4wire.com/forums/showfl...ev=#Post921322
Old Nov 17, 2006 | 10:56 AM
texsurfer's Avatar
I built longer shackles and kept the nice ride.
Old Nov 17, 2006 | 11:06 AM
Bill's Avatar
I can't remember where I saw it, but I remember reading about a guy that built his own "helper" springs out of TJ front coils. He said he got about 2" of lift out of them, and they work well.
The only down side I can really see to using that type of a set up is loss of droop. Sure you're regaining your original ride height, but it's also going to require a lot more(and a fancier retaining system) to make sure that when you droop the axle, the coil stays where it's supposed to.
Old Nov 27, 2006 | 10:49 AM
spudrunner's Avatar
Hi, found this thread where a guy used these jc whitney helper springs to get 2" of lift on his '88 and 3" with his mod.
http://gearinstalls.com/helper.htm
Old Nov 27, 2006 | 10:57 AM
spudrunner's Avatar
Here's another good link.
http://gearinstalls.com/dc.htm
Old Nov 27, 2006 | 11:09 AM
zoe17's Avatar
I have a saggy 89' Four Runner also. I went to ranchos site and they do not list toyota as an option. I would like to replace the rear leafs or add a leaf. I am not looking for lift, just to get the sag out as I want to keep close to stock. I just put on new Rancho 9000's that where stock length. Any site recommended vendors with a leaf spring kit/fit for this?
Old Nov 27, 2006 | 11:14 AM
4Crawler's Avatar
http://www.gorancho.com/flash/rancho.html
Click on "Add-a-leaf/Lev-a-load" file, scroll down to page 8.
Old Nov 27, 2006 | 11:32 AM
zoe17's Avatar
Found the .pdf file and cat#
Thanks
voiddweller
19
May 2, 2016 09:10 PM
stagger_lee
Mar 29, 2016 06:27 PM
red88toy
11
Aug 3, 2015 07:47 PM
merc1100sc
Jun 26, 2015 05:24 PM
chbarnha
Jun 18, 2015 10:23 AM
