Rear Defrost
Old Dec 3, 2009 | 01:18 AM
dub tek's Avatar
Rear Defrost
Hello ALL
Been playing with toyota wiring for a few days now.
Found and replaced water intrusion in the wiring along drivers side floor board.
1988 toyota 4runner 22re 5spd dlx.
......QUICK QUESTION......
WHATS a normal RESISTANCE measurement of the rear defrost grid?
I know it will vary, but some averages would be great!
My service manual tells me everything but that.
It now says to replace rear window at the last step of diagnosis path...
Just trying to get this ONE last thing back up and running in my 4runner
and I have Power + Gnd like I am directed by FSM.... but NO heating
Thanks for ALL the help yotatech
Jeff.
Old Dec 9, 2009 | 02:00 AM
AKZEP69's Avatar
Test for broken leads?
I was able to resurrect mine with repairs to 2 wires with the paste -
check + wire where it connects to the glass? If broken ...then it's fubared.
Fyi -new rear glass is $700 or more
good luck
Old Dec 30, 2009 | 03:13 PM
TheExonerator's Avatar
I have no rear defrost either. I went through the fuse and the switch, and started taking the rear door apart when it started snowing really hard. Sucks not having a garage.
Anyways, I also have no light when I press the defrost button (which is why I thought it might be the switch).
Anyways, any tips would be great. Like maybe the next place I should look into.
I'm a newbie, and want to take as little apart as possible due to the cold weather and snow etc.
Any help would be very much appreciated.
Old Dec 30, 2009 | 04:45 PM
dub tek's Avatar
posted this a while back
never got any further info from the boards
I will say that I solved my issueS
first I had NO sitched signal into the relay from dash switch
Signal wire was cut under plastic foot well trim
Second there was NO B+ to the rear window control module
Located behind the drivers side, rear seat, side panel....
Its switched into the module for window location (full UP+Down)
Found I had proper power and GND from relay to rear window connections
thats when I started the thread..
Further testing showed i had a voltage drop of near 10 volts from relay to the rear window.
Replaced that wire
ALL is well for now
salty roads KILLS EVERYTHING.........
Old Dec 30, 2009 | 05:56 PM
Yeah no . I'm in Salt Lake City, and there is tooooo much salt.
So, I guess I just have to keep following this wire. I guess I'll check under he driver side foot well. Its by the door right?
Maybe that'll do the trick.
MO transplant
Apr 23, 2023 11:58 AM
okamikai
Apr 30, 2018 10:19 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
