Rear Braking Problem & LSPV
I had to change the lines going from the front to the LSPV (load sensing proportioning valve). Unfortunately I did not keep track of which line goes where. I searched the forum, but could not find the answer or any other place online. I also have a Haynes book, but it does not give a diagram (what did I buy the book for?) Which line coming into the lspv comes directly from the master cylinder? Is it the top line or the bottom?
The symptom that makes me think that I might have a problem here is that after replacing the lines and the master cylinder I don't have very good brakes. Sometimes I have to pump the brakes in order to get enough braking power. I have bled the system multiple times and have no air coming out anywhere.
Also, I don't seem to have any rear brakes. I know this because when stopping on gravel the fronts would lock up, but the rears wouldn't seem to be doing anything. I adjusted up the one drum, but was unable to get the drum off on the other side. I don't know if this could be the problem. I do get pressure on both back bleeders when I bleed the lines which I have been told should indicate that they are adjusted ok (or at least enough to give pressure). I have not adjusted the lspv, which I may still do. The fact that when I bleed the rear and I get fluid indicates that it must be allowing fluid by, but I may be wrong here.
Any help would be appreciated. Thanks.
Try this link, it might help. Like I said before I don't know much about the LSPV
http://www.off-road.com/toyota/cheaptricks/brakevalve/
Look which line goes where
Originally Posted by LOCKnGO
I'm glad you posted this, I was thinking of removing the LSPV all together, and installing a manuel PV. This is a lot cheaper.
Originally Posted by bereanmh
When you take yours off to replace it, can you look to see what line goes where in the old proportioning valve. Thanks.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
