Rear Add A Leaf
Rear Add A Leaf
I am Looking for a Add A Leaf Kit For My 88 4runner. I want to just keep my Truck "Level" with 33" Tires on it. Meaning I want to Raise the Rear to Clear Tires ok, Then do a Torsion Crank Job on the Front to Match the Rear. I Don't want to Crank the Torsions to the Moon. Because it makes the Truck Bouncy. I am Thinking I need a 1.5" to 2" Lift to the Rear. I want to Keep the Ride Good Though.
Any Ideas?
Oh Yeah, I am thinking About 33X10.5 BFG Mud Terrains. Do I even Need to Lift the Truck at All?? The Rear end Only Sags a Little. But, I Really Like the OEM Look. I Have to Keep this Cheap Because the Truck Is'nt in that Great of Shape.
Thanks in Advance
Dax
Any Ideas?
Thanks in Advance
Dax
Don't crank the bars. Put the BJ spacers for the front and uses shackles in the rear. This will not effect ride quality at all and it will give you the lift you wanted. Look to spend roughly $100 for the spacers and $65 for the shackles. Add-a-leafs gives you a stiff ride and cranking the bars up does the same as well. Search for ball joint spacers and you will find everything you need to know.
James
James
Don't need any lift for 33x10.50, so the shackles in the rear to level it out should take care of it. Keep in mind that you need to order a shackle twice as long as the lift you want. So, if you want 2" lift, you need a 4" shackle.
Originally Posted by V_Runner
whats the difference btween shackles and aal's...pros-cons....price wise,and instalation wise
With the add-a-leaf it gave it the arch back.
Then i installed some 1.5" shackles in the rear. This really raised the butt up.
Over all with the add-a-leaf and the shackle lift i was quite happy. The ride was really nice.
I picked up the add-a-leaf from a friend here on the board and i purchased the shackles from Central 4wd.
Here is a before and after shot.
Before:
After shot:
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
icentropy
Jul 14, 2015 10:23 AM
