Rain killed my truck ????????
Old Dec 6, 2007 | 01:41 PM
1990arizona4runner's Avatar
I own a 1990 4-Runner 4x4 V-6 Automatic. I live in central Arizona and it doesn't rain much but the other day it did and now my truck won't run right. I was driving home from work when all of a sudden it just died out, then wouldn't start back up. I finally got it home and a week later its still doing it. When it dies out, there is no power at all anywhere in the truck. The starter doesn't turn over and the clock or lights won't even turn on. I checked the battery and connections and they seem to be fine. I also noticed that my inside dome lights quit working all together. Does anyone have any advice or suggestions. I think its the wiring but I have no idea where to start looking. This is my everyday driver. I need some serious help.
Old Dec 6, 2007 | 02:25 PM
notanymore's Avatar
i dont know how rain might cause this but check all of your grounds, what you describe sounds alot like what happened when my ground went bad
Old Dec 6, 2007 | 02:26 PM
az4x4runner's Avatar
I don't know how moisture would have gotten in too easially, but maybe check under your distributor cap for moisture. Also any wiring near the firewall may have gotten damp.
Old Dec 6, 2007 | 02:58 PM
thook's Avatar
Do you have a sunroof?
Old Dec 6, 2007 | 03:07 PM
rowdy235's Avatar
check and clean all battery terminals and all grounds. Weird things can happen when they get corroded/dirty.
Old Dec 6, 2007 | 03:15 PM
frodin1's Avatar
Multiple ditto on the ground problem!
ozziesironmanoffroad's Avatar
thats weird, im in vegas, and it doesnt run correctly unless its raining. hahaha.
Old Dec 6, 2007 | 04:35 PM
Paul H.'s Avatar
Do you have to jump it to get it started again. If so then it might be the alternator.
Old Dec 7, 2007 | 12:58 PM
sh0kk86's Avatar
hope you get it fixed it soon man, we rarely get rain and when we do itd suck not being able to go play in the mud
Old Dec 8, 2007 | 01:46 PM
Squeebs's Avatar
I was having a starting problem... on and off for a year or so...
Narrowed it down to the positive cable on the battery.
The end at the starter was totally corroded so sometimes i couldn't get enough current from my battery to the starter to get the engine to turn over.
Anyways...
New battery, starter fuse, fuel injector fuse, battery wiring, and dome light fuse later.... its all pretty.
MadMax48
Jul 3, 2015 08:26 AM
Dennis140
Jun 17, 2015 10:37 AM
mark from uk
10
Aug 2, 2002 07:23 AM
