Question on Cali 22RE O2 sensor
I have a '94 22RE Pickup w/146,000 miles.
The oxygen sensor behind the cat (its the CA emissions style exhaust) is so rusted that the nuts broke off and the o2 sensor isn't being held on by anything.
Rather than replacing this after-cat sensor, can I just weld something over the hole instead to bypass this o2 sensor? Or would that screw up the ecu?
or you could do what i did by a o2 simulator from http://empirepao.com/ no engine light you can completely remove the sensor and now you can gut the cat like i did. catalog number 1301 in the o2 simulator section. it was a really good quality item and had a very simple plug and play install.
i run header w/ no cat and both O2 sensors with no check engine light.
zz_denis
Sep 6, 2015 03:43 PM
