power windows broke after removing alarm system
Old Apr 19, 2007 | 05:22 AM
monst's Avatar
Arg... so this alarm system keep falling infront of my feet while driving... So i had to gank it... now the power windows don't work except the drivers window. any idea what the wire colors would be or how to trace it back... i hope i didn't perminately kill them
Old Apr 19, 2007 | 06:45 AM
Stevo3's Avatar
Just a suggestion, Put the alarm system back in and reziptie it back on the steering cloumn?
Old Apr 19, 2007 | 06:51 AM
WFO's Avatar
WFO
Did you check and make sure the window lock button isnt on???
Old Apr 19, 2007 | 07:04 AM
WATRD's Avatar
By chance, was the alarm wired to roll up the windows when it armed? If so, you have to interrupt a wire to make that happen. When you removed the alarm you broke that circuit.
Nothing is permanently dead, but you are going to have to trace some wiring to find where the alarm was inserted into the window circuit.
As you found out, you can't just cut an alarm out. You have to do a complete uninstall, which includes putting the wiring back to the way it was before the alarm was installed. You are lucky it wasn't an ignition kill that engaged...
Best of luck!
Old Apr 19, 2007 | 08:34 AM
monst's Avatar
I need to find the wiring manual for a "elite codealarm" alarm... that way i can reverse the process...
Old Apr 19, 2007 | 08:57 AM
monst's Avatar
OK i just called the company that makes the alarm system. they said there is nothing in the alarm that would cause the windows to stop functioning...
So i think i might have knocked a wire loose...
Also the driver window & very back window is the only windows one i can roll down... So i assume the fuse isn't blown.... any ideas where i can find a wiring guide or maybe ideas on how to figure this out..
Old Apr 19, 2007 | 09:44 AM
UncleBob's Avatar
You SURE the lock switch isn't in the locked position? It's acting like it.
Here's the wiring for the windows, and a way to test the Master Switch Lock for functionality.
http://personal.utulsa.edu/~nathan-b.../7powerwin.pdf
Old Apr 19, 2007 | 09:51 AM
monst's Avatar
Uncle bob, i cant roll down any of the winows from the drivers side control panel.. ill go double check the lock
Old Apr 19, 2007 | 09:53 AM
monst's Avatar
ROFL... that was it the whole time.... GOD im a retard sometimes!!!
thanks again dudes...
Old Apr 19, 2007 | 10:18 AM
WATRD's Avatar
Bwhahhahahahahahaha!
I am glad it was something simple.
hahahhaaha
Old Apr 19, 2007 | 10:20 AM
UncleBob's Avatar
Everybody is a little bit retarded, don't sweat it.
A few weeks ago, I couldn't figure out how to make the stupid 'Back-Door' light go out on my dash. I searched the FSM, Yota-Tech, etc, only to end up posting and found out I had to push down the tailgate lock button.
Doh!
Old Apr 19, 2007 | 04:18 PM
leebee's Avatar
welcome to the club, there are more members out there!
lee
Old Apr 19, 2007 | 07:59 PM
toyota_mdt_tech's Avatar
The connectors for the door harness is right in the LH kick panel, it will be obvious once you get the cover off.
Old May 8, 2007 | 05:56 PM
rusmotor's Avatar
Wow, here is an idea! My windows except driver one and sunroof stoped working couple days ago. I will check the lock switch tonight!
Old May 10, 2007 | 06:59 AM
rusmotor's Avatar
Monst, you're not alone!
Checked my lock botton yesterday and yes - that was it!
Thanks guys!
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Johntom240
7
Jul 13, 2015 12:18 AM
ItsJustD
Jul 7, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
