power steering/ timeing?
Old Mar 20, 2009 | 04:50 AM
yoterr's Avatar
can some of you guys post a pic of your powersteering pump and the pulley?, my trucks got the pump (not sure if it works) but im pretty sure it needs another pulley to get around the fan, trucks a 22R.......Also i was changing the alternator yesterday and noticed my dist is turned all the way to the right (clockwise) seems to run ok, its supposed to be somewhere in the middle right? not to far advanced and not to retarded , mind you i just bought the truck 2 days ago, thanks in advance guys
Old Mar 20, 2009 | 06:26 AM
874runnersr5's Avatar
does this kinda help?
Old Mar 20, 2009 | 08:38 AM
yoterr's Avatar
kinda, does your have a separate pulley from the fan? or does it just run on the fan? ill get some pics of what i got up here in a min
Old Mar 20, 2009 | 08:49 AM
yoterr's Avatar
all right heres what im workin with (click link) theres the powersteering pulley to the right then the fan pulley but its only got one rib for the alternator, theres a threaded hole in the block just under the vac advance lines i think thats where the pulley goes but not sure
http://i227.photobucket.com/albums/d...a/100_1255.jpg
and heres the new truck
Old Mar 20, 2009 | 08:53 AM
4Crawler's Avatar
3 belts on my 22RE, alt/water pump on the inside, A/C in the middle and P/S on the outer pulley:
Old Mar 20, 2009 | 09:08 AM
yoterr's Avatar
do you have an idler pulley for the power steering? good pic btw
Old Mar 20, 2009 | 09:14 AM
4Crawler's Avatar
Yes, it has the standard idler/tensioner pulley:
Old Mar 20, 2009 | 09:20 AM
yoterr's Avatar
ok cool, thats what i was wondering, im prolly gonna have to find the bracket in a junkyard er somethin right? also say this pump doesent work, can i get a seal kit and fix the prob? or is that just for a leaky one? $100 bucks for a new one, im gonna try n rebuild it for $16 thanks for all the help guys
Old Mar 21, 2009 | 09:20 PM
waldrake's Avatar
I just found this... I'm actually trying to pull out my power steering pump right now. It's been dead for a while; I had to replace my radiator so now seemed like a good time to fix the pump.
I've got a Chilton Guide and I can't make heads or tails out of its steering pump diagrams. Mine is an 85 22r pickup. I've got three belts, and I can't see anything that makes contact with what I think is the power steering pump.
Do the 22r and the 22re use the same steering pump mechanism? These pictures so far have been helpful... I don't suppose anyone could go so far as to take a picture and label things, hmm?
Thanks!
Old Feb 1, 2016 | 02:48 PM
Papadeath's Avatar
I'm trying to do this swap.... can anyone, for crissake, post a diagram of the hose configuration? Its all bolted in but don't know where these hoses go. PLEASE
Old Feb 2, 2016 | 09:31 AM
4Crawler's Avatar
The vacuum two lines from the p/s pump hook up where I have the red caps in the image on this page:
- mhttp://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/11.html
Old Feb 4, 2016 | 03:11 AM
Papadeath's Avatar
i pretty much figured it out now. The gearbox i wound up with goes to a 4x4 and does not fit mine. I have already modified and fabricated and welded and shoved it in, and it appears that it is working somewhat but it is binding as it is noooot quite straight. .. almost. Seems a tiny bit off is all it takes. Ive already shimmed it but looks like im going to have to drill at least one more hole through the frame
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
