Power steering problem
Old Aug 19, 2018 | 06:50 PM
85basemodel's Avatar
Hello guys i recently took my 1990 toyota pickup mudding and i had got stuck and turning trying to get out after i got home i relized im leaking power steering fluid from where the steering shaft meets the gear box is im guessing its a seal but is that an easy fix?
Old Aug 20, 2018 | 04:48 PM
Co_94_PU's Avatar
Yeah, no...
It is a serviceable part, most don't bother and grab a junkyard one.
However if you have to ask, your going to have to do some research. Consult the FSM and see if it's something you feel OK with. Then hunt up the parts.
Old Aug 20, 2018 | 05:05 PM
Originally Posted by Co_94_PU
Yeah, no...
thanks
Old Aug 20, 2018 | 06:54 PM
Thommo Thompson's Avatar
id be tryign to find a seal kit.
can you show me a picture of the rackand i can probabyl get you the correct aprt number and find it online.
Old Aug 21, 2018 | 03:40 AM
scope103's Avatar
I'd start with the manual. http://web.archive.org/web/201209150...ng/13gearh.pdf The seal can be replaced, but the whole thing looks pretty daunting to me (lots of Special Service Tools; do you have a torque wrench that will read 4.3 inch-lbs?) With more information about your rig, the part numbers can be found here: https://parts.lakelandtoyota.com/sho...rimLevel=18381 The seal alone is not that expensive.
RockAuto has remanufactured units for around $200. I think that's the way I'd go.
Old Aug 21, 2018 | 09:47 AM
yeah i can
lmddmc
Oct 9, 2014 11:42 PM
rydholm11211
Jul 4, 2013 04:45 PM
toyotatrdsr5
Jun 16, 2011 12:15 PM
4x4YOTA
Mar 10, 2009 05:13 PM
loacyota
Mar 16, 2008 01:33 PM
