power steering mysteriously not working anymore
Old Aug 25, 2018 | 10:19 AM
Charlie Nelson's Avatar
after doing some donuts in a field in my 86 22re, my power steering no longer works. i dont see any leaks and its still full of fluid so what could be the problem here? how can i tell if the pump has gone bad? i was going pretty hard on the truck but all the power steering stuff looks ok, i dont see anything wrong. what can i test or check to find what isnt working? as i drive it more and go in and out of my drive way ive found that sometimes it will work and sometimes it doesnt. its completely random.
Old Aug 25, 2018 | 11:17 AM
87-4runner's Avatar
Sounds like it's going south...
L5wolvesf's Avatar
Is the belt on snugly?
Old Aug 25, 2018 | 11:26 AM
Co_94_PU's Avatar
Can try burning burping the air out of it, it's not designed for long hard cornering and may just have sucked in some air when the fluid was sloshed against the wall, could have been ran dry long enough to kill it also...
Edit: autocorrect got me.burb not burn.
Old Aug 25, 2018 | 11:29 AM
the alternator belt is actually alittle loose, i already knew this though, its been making a slipping noise for the past couple days but i didnt think it would be related to power steering
Old Aug 25, 2018 | 11:30 AM
Originally Posted by Co_94_PU
Can try burning the air out of it, it's not designed for long hard cornering and may just have sucked in some air when the fluid was sloshed against the wall, could have been ran dry long enough to kill it also...
how does one burn the air out? is there a way to actually check if ive killed it or do i just have to assume its dead and try a new one?
Old Aug 25, 2018 | 02:08 PM
L5wolvesf's Avatar
I was referring to the power steering belt
Old Aug 25, 2018 | 05:22 PM
that belt is fine, not loose or anything, only a few months old
Old Aug 25, 2018 | 05:33 PM
outdoorjunky's Avatar
5 Year Member
You can bleed the system by opening the cap on the reservoir then turning the wheels back and forth. When you add new fluid to the system (if you do) you should turn the wheels all the way left and all the way right a few times to get the fluid flowing into the pump and add more as needed (without the engine running). If you let these run dry it ruins them for good. I just replaced mine and had no issues with fill at initial start because turning the wheels gets the air out and essentially primes the system with oil to ensure it's not starting off dry as it tries to suck from the reservoir. If the pump is toast some of the seals may just need replacing in it but it could also be the vane assembly is worn or the bearing is shot in in which case a new pump would probably be easiest. there is a rebuild kit available at NAPA and basically all parts retailers but a reman pump is only 82$ at NAPA with core. just make sure if you get a reman pump that you check that the spring loaded flow control valve isn't stuck like mine was... because they paint the remanufactured pump housings some of the paint prevented the valve from opening and my pump was in bypass until I removed it and broke it free a bit, now my steering is like a hot knife through butter.
Old Aug 26, 2018 | 10:17 AM
outdoorjunky so i bled the system and my power steering worked again for a few seconds and then it went out again. after i bled the system, i turned the wheel back and fourth to see if it fixed my issue and it only worked for the first couple turns and then it was out again. one of the lines from the resi is also very oily and greasy from the outside https://imgur.com/a/g1wWziU?s=sms , theres some pics i took. it has always had some grease or oil on it since i bought the truck but it was never that bad. i did not try new fluid yet, could that fix my problem? it sounds to me like the pump cant be shot because it still works sometimes, am i right or am i wrong?
Old Aug 26, 2018 | 11:45 AM
5 Year Member
looks like either the reservoir hose is leaking or your high pressure hose has sprung a leak and sprayed the other hose down. Your hoses look like they could use changing. If that high pressure hose bursts it can spray ATF fluid on the alternator or exhaust and cause a fire in the engine bay (your truck uses ATF not power steering fluid just FYI). Is the leak actually coming through the protective coating on the high pressure hose and leaking down on the reservoir? The hose I’m talking about Is the one with the banjo like fitting that screws in to the pump bellow the reservoir hose and then makes a loop and then goes down to the steering box/ram mounted to the frame. Trace it from the pump end and inspect it for cracks, mine looked ok until I flexed it a bit and then I noticed huge deep dry rotted cracks and went out and replaced it immediately. If that hose is leaking get a new one from NAPA asap ... the OEM one is 250$ but the Napa one is pretty high quality and costs 44$
Old Aug 26, 2018 | 01:11 PM
5 Year Member
Also did you notice lots of little bubbles in the reservoir when you checked fluid? If so that can be a sign that air is still in the system and or air is being introduced through a leak in one of the hoses.
Old Aug 26, 2018 | 04:50 PM
i inspected the high pressure hose and i dont see any leaks anywhere. i think ill still replace the hoses just incase. would you by chance know the part number for it from napa? also i bled the system again and no air came out and there wasnt any bubbles in it when i took the cap off so i think by now its fully bled.
Old Aug 26, 2018 | 05:13 PM
5 Year Member
It’s good practice to replace that hose because of the risk of fire but has bleeding off the air fixed your issue? Somehow the air got in there so that tells me something isn’t right someplace else. You should inspect your steering box for leakage as well to make sure that didn’t quit on you. If the seals in either the steering box or the pump go you can loose hydraulic pressure and end up with no power steering. From what I read about the steering box the front seal likes to go from time to time, usually you’d see a leak though as far as I have read. Lucky for me the steering box is the one thing that wasn’t Jerry rigged on my truck and the previous owner recently replaced it, however, he didn’t feel inclined to replace the pump that was leaking all over the alternator when he did it lol. Anyway Is your steering sloppy at all? That can be a sign that your steering box needs replacing. Otherwise what others who commented have said could have happened ... because your reservoir was leaking there could have been room enough for air to get in and cause your pump to run dry momentarily and the vanes got damaged in the process... while you were tearing it up with the doughnuts 🍩 🤘🏻
Old Aug 26, 2018 | 05:40 PM
i inspected the steering box and i dont see a single leak or even drop of grease or oil on it surprisingly. im gonna test for sloppy steering in the morning and also see if the power steering is back then, its to late right now to run it, dont wanna upset the neighbors! what do you mean by veins? are those the metal lines?
Old Aug 26, 2018 | 06:04 PM
5 Year Member
My phone was putting words in my mouth or I had a brain fart ... VANE not veins ... the vanes are these little pieces is metal that get pushed out via centrifugal force and get the fluid moving. This is the inside of the one I attempted to rebuild but I still had a leak after and I think I may have damaged an oring when reassembling andjist got a new reman for 80$ instead of rebuilding a second time.
Old Aug 26, 2018 | 06:06 PM
5 Year Member
little pieces OF metal. Damn this site is impossible to edit from a phone browser if there are any images in the post.
Old Aug 26, 2018 | 06:20 PM
lol. ok i see what you mean now. im gonna see how it is in the morning, if its not working then ill try new lines and after that ill try the new pump. wish me luckk
Old Aug 26, 2018 | 06:26 PM
5 Year Member
If bleeding isn’t working but for a few seconds then “Lucy we have a problem” (with the pump) ... but if you want the replacement pump to last you should also replace those hoses . Sounds like your steering box is okay since you say it looks super clean and bone dry (it was probably replaced somewhat recently)
Old Aug 26, 2018 | 07:16 PM
87-4runner's Avatar
Good luck...
spddm0n
Oct 12, 2017 05:36 AM
Gamefreakgc
Jun 18, 2014 09:05 AM
-=j0nnyr0773n=-
Oct 5, 2008 08:49 AM
