Potential Buy 93 v6 needing gas tank etc
Old Sep 7, 2014 | 05:06 PM
sl0annuggets's Avatar
Opportunity to buy a 93 v6 5spd 4x4 but it needs a gas tank, fuel pump assembly and sending unit.
It has quite a bit of new stuff
"Lots of new parts
4 wheel drive works great
manual hubs shift smooth
Engine runs strong
Replaced gas lines to tank
New clutch master cyl
New slave cyl
New wheelbearings
New ball joints
New calipers
Brakes one year old all new
New tires"
Trying to grab it for 1000.
It also says that the old tank is out of the way, ready for new parts. As long as the frame is good this should be a solid deal right?
Isn't the fuel pump is inside the gas tank? so I could install that nice nice without having to be under the truck right?
Old Sep 7, 2014 | 06:43 PM
Terrys87's Avatar
I clean my tanks out and a fuel pump is easy to get. You are correct about the fuel pump being in the tank. The assembly that holds the pump can run around $150 and depending on where you live can be hard to find. Check the yards or online for a pump holder assembly.
TheBFA
Feb 15, 2020 06:55 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
