Post pics of 90-95 4Runner IFS lifted pics
Old Oct 26, 2010 | 04:57 PM
  #141
HighRunner's Avatar
I can assure that that is indeed all that I have. I think my 4Runner is a bit of a factory freak, it seems higher than most in its stock form. Well the front that is, because it sure had the classic rear azz sag when I got it
Old Oct 27, 2010 | 11:44 PM
  #142
85toyman's Avatar
Here is my little creation. Downey HD rear springs, Downey Mega Travel Ball Joints, 4Crawler BJ spacers, pan hard drop bar, sway bar drop and diff drop kit. I had the Downey rear cross member installed but the drop on the diff didn't allow the cross bar to stay. I have factory hubs as well, so I might put the diff back and see how the cv's like it. 4:88's as well with 33x12.5x15 BFG mudd's. I have ordered some shocks and a steering stabilizer. Should be here next week.
Old Oct 28, 2010 | 07:40 AM
  #143
Teuf's Avatar
I see an alignment coming? YES?
Old Oct 28, 2010 | 07:56 AM
  #144
85toyman's Avatar
Yes, the alignment was done later that day. I just have not had a good day since to take pictures as it has been raining non stop the last few days. The front end looks much better now and drives so much smoother.
Old Oct 28, 2010 | 02:19 PM
  #145
drmix's Avatar
Theres alot of good looking runners in here.
Anyone know if theres a thread like this but for pickups? I searched but couldnt find any
Old Oct 28, 2010 | 02:25 PM
  #146
JamesD's Avatar
There should be. They should separate by generations and make it a sticky.
James
Old Oct 28, 2010 | 02:50 PM
  #147
drmix's Avatar
Im surprised this isnt a sticky already. This will eliminate all the "will xx tires fit on my on 4runner with a x lift?" threads or the "What do xx tires look like with a x lift".
But there should definitely be one for 89-95 pickups even though 4runners are pretty similar
Old Oct 31, 2010 | 01:17 AM
  #148
HighRunner's Avatar
85ToyMan - I'm kinda surprised that your coil springs are black? My Downey HD's were coated grey. What's up with that I wonder?
Old Oct 31, 2010 | 01:53 PM
  #149
85toyman's Avatar
highrunner- they are powder coated grey as well, the light under the rig makes them look black.
Old Oct 31, 2010 | 02:57 PM
  #150
Crimson Yota's Avatar
Sorry for the noob question guys but,
What is a panhard drop bracket?
Old Oct 31, 2010 | 03:06 PM
  #151
JudasPainkill3r's Avatar
I'm sure everybody has asked noob questions at one point or another.
"The panhard rod drop bracket lowers the frame end of the panhard rod to compensate for the rear end lift. The panhard rod helps to locate the rear axle side to side and if not adjusted for the lift, it will tend to pull the axle towards the passenger side due to its higher angle from the frame to the axle bracket. An easy way to check the offset on the panhard rod is to use a tape measure and measure the height off the ground of the center of the mounting bolt on each end of the rod. The height difference between the two ends would be amount of drop your rod needs to be restored to level. Note that it is not critical to match that height difference exactly. For example, if your rod is offset 3" from level, then a 4" drop brkt. would leave you with a net 1" offset, but that would be far better than the 3" offset that is currently there."
4Crawler has some really good drop brackets. Due to my rear end lift being 6 inches, i ordered a 6" panhard drop bracket to compensate. I've pasted a link below for you to see what they are. You'll have to scroll down the page.
Panhard Drop Brackets
Old Oct 31, 2010 | 03:55 PM
  #152
Thanks, so it basically levels out your rig? Is it something that always needs to be done or is it just some people that need it?
Old Oct 31, 2010 | 04:07 PM
  #153
I think any yota that has a panhard rod in the rear and that has a lift installed should have the appropriate panhard drop bracket installed. Currently, i have 6 inches of lift in my rear but i've only been using a 4" drop bracket which has caused the driver rear side to dip down a little (truck looks lop sided from the rear) and the whole axle housing is pulling out towards the passenger side of my truck. I just ordered the 6" drop bracket to hopefully fix the lop sidedness of my rear end and to make my axle housing sit in the middle and not to one side.
Old Nov 1, 2010 | 11:28 AM
  #154
85toyman's Avatar
The panhard bar is the bar that runs accross the back side of the rear axle. It limits lateral (side to side) movement of the rear axle. When you lift the 4runner it drops the part of the bar that is attached to the frame of the vehilce. This difference in height will pull the rear axle towards the right side to make up for the difference in height compard to running level at stock height. When you put the drop bracket in it lowers the rear bar to a more stock level height and centers the rear axle.
Old Nov 16, 2010 | 06:22 PM
  #155
stankydank420's Avatar
Originally Posted by JamesD
That is an AWESOME truck my friend but this thread is for lifted IFS 2nd GEN 4Runners not trucks. Trying to keep it 4Runners so when people search they can find what they are looking for. Post more pics and what you got. I absolutely love that truck!!
James
Looks like the Back to the Future truck! Nice.
Old Nov 19, 2010 | 06:01 PM
  #156
HighRunner's Avatar
People we're letting this thread die! C'mon, more pics!!
Old Nov 19, 2010 | 06:16 PM
  #157
Agreed.
Im gonna post some updated pics of my 4runner tomorrow. Just got my winch, bumper, lights and skid plate on and tomorrow morning my 35's are going on.
Old Nov 19, 2010 | 06:27 PM
  #158
toyota4x4907's Avatar
Originally Posted by Want_2_Wrench
When I first got it. 3" body lift to clear the tires and the 3.4 motor swap.
Then I put a ToyTec 2" lift with BJ spacers and the heavy duty rear OME springs.
These are old pictures but since then: XD9000 installed, all roof junk removed along with running boards, and the light have been rewired. Planning on chopping it and possibly bobing it this summer along with lockers.
I was wanting to buy that rig when it came up for sale last year or whenever. Too bad I was in FBX and it was in Wasilla, other wise I probably would have gotten it.
Old Nov 19, 2010 | 06:28 PM
  #159
HighRunner's Avatar
Originally Posted by JudasPainkill3r
Agreed.
What skid plate did you get?
I guess I'll see tomorrow!
Old Nov 20, 2010 | 04:12 PM
  #160
85toyman's Avatar
Bumper looks nice, just need to save for a winch now. I want a winch bumper so bad. Problem is, I would have to buy another winch for the rear end. Ah oh well, I dont have anything else to spend money on, like a house payment or anything.
