Pillar Rust
Old Dec 31, 2007 | 03:08 PM
DanStew's Avatar
Pillar Rust
Like all Toyotas I ahve the pillar rust on the passenger side on the windshield frame. My question is what have you guys used to treat the rust? Right now i have no time to do it "right" but pulling the glass and getting under it. I am curious if there is any rust converters (that arent acid) that will flow like water into the rust area? I thoguht bout Ospho but that will eat the heck out of the rubber seal.
Old Dec 31, 2007 | 08:16 PM
InternetRoadkill's Avatar
The rubber seal is urethane adhesive. It's really, really tough. I don't know of any chemicals that will dissolve it so that's not an issue. A rust converter is probably not going to do much for you unless you get the loose scale off first which is going to be hard to do with the glass in place.
Old Jan 1, 2008 | 05:21 AM
DanStew's Avatar
Fortunately i do not have much scale. The rust isnt bad (from the outside) so i want to treat what is visible. No telling what it looks like under the seal, but since i am not in the rust belt i can hope it isnt that much.
Old Jan 1, 2008 | 06:14 AM
waskillywabbit's Avatar
When a person has a rash on the outside of their body that is visible it is usually 10 times as bad on the inside.
DIY in fixing the rust and r/r the windshield and you won't be out anything more than the windshield replacement materials and whatever it takes to fix the rust. I fixed one on my 87 and the windshield was perfect but it cost me $100 to have it professionally r/r (I didn't have the time at the time) so I could fix the rust. Wire brush, some welding and cleanup with a grinder, some primer and paint and it was done. Given, it was some spray paint from Lowes.
I'd do it now...ASAP...as it will only get worse (on the inside)
Old Jan 1, 2008 | 06:39 AM
JamesD's Avatar
Usually what causes the rust is when someone who replaces the windshield doesn't properly prep the surface after they dug out the urethane with tools. All the Toyota trucks I have owned had the windshields replaced and rust around the pillars.
James
Old Jan 1, 2008 | 07:45 AM
The problem is that dirt and debris get trapped under the trim and it holds water causing the rust. Whatever rust is visible, you can expect 10x more that's hidden.
Old Jan 1, 2008 | 03:05 PM
Flash319's Avatar
Chainsaw bar oil. It will keep it from getting worse until you can fix it. That is what I undercoat with.
Old Jan 1, 2008 | 04:49 PM
TORTIS's Avatar
i agree with the wabbit. it is like cancer, get it all or it will come back.
I8URSVT
Mar 2, 2021 06:23 AM
RDubya
Feb 10, 2017 04:46 PM
tylermx71
Sep 29, 2015 08:49 PM
toyotasaurus
Sep 24, 2015 03:30 PM
94toyy
12
Sep 14, 2015 06:18 AM
