Parasitic draw? dies overnight
Old Mar 25, 2008 | 01:23 PM
aviator's Avatar
Had this problem one time and it was moisture/corrosion on the top of the batt./terminals causing a leak to ground. Another time with my current truck and it was old wiring from PO's removed CD changer that was split and causing a leak to ground when wet but not enough to blow the in-line fuse.
Removed all PO's garbage wiring installed new Batt. [1200CCA tow truck batt.] and no worries since so far as that went...
Steven.m.paulk
Jun 7, 2020 10:45 AM
shisha1999
Mar 3, 2016 07:09 PM
Chicken12
Oct 14, 2015 03:54 PM
Rcbc92
Sep 26, 2015 03:00 PM
