Oxygen sensor brand preference?
Old Oct 25, 2009 | 04:55 PM
YFZsandrider's Avatar
I know you guys were saying that NGK and Denso O2 sensors work well, but most of the suppliers around me stock Bosch. Anything against using that brand?
Old Oct 25, 2009 | 05:36 PM
eric-the-red's Avatar
For some reason Bosch and Toyotas just don't mix. Search further and get a NGK or Denso, even if you have to pay a few $ extra at a dealer.
Old Oct 27, 2009 | 07:29 PM
YotaTron88''s Avatar
You can clean your old one with a torch and burn all the carbon off it. A world class engine builder tought me this years ago......heat em till they glow red. Good as new!
Old Oct 27, 2009 | 10:26 PM
...unless the O2 sensor has a melted plug because the P.O.S. previous owner had it unplugged, and resting against the exhaust pipe!
Old Oct 27, 2009 | 10:42 PM
srozell's Avatar
Is this for real? is the carbon build up the main thing that degrades the sensors?
Old Oct 27, 2009 | 10:52 PM
Ya....try it!
Old Oct 27, 2009 | 11:01 PM
sb5walker's Avatar
This thread has some good info, including why Bosch O2 sensors often don't work well in our trucks:
https://www.yotatech.com/forums/f116.../#post51247728
Just heating something usually won't remove carbon. I've read of heating the business end of the sensor almost red hot and then quenching in water with some isopropyl in it; doing that several times. Apparently the quenching causes the carbon to flake off. I think there would be a risk of cracking the ceramic, also, so I would only try it on a sensor that needs to be replaced anyway.
Things other than carbon can kill an O2 sensor. Getting RTV into the combustion chamber will kill the sensor in a big hurry. Zinc from certain oils, if the motor is burning oil, won't do it any favors, either. I doubt that cleaning would resurrect a sensor killed by either of those.
Denso direct fits will be the safest choice. Get the mfr part # from sparkplugs dot com & search for 'denso' and the part # on amazon - been cheap there this year.
Old Oct 27, 2009 | 11:23 PM
It worked to clear the codes in my buddies 11 sec misu eclipse....he was an mec. engineer. Did a bunch of cool things I could never think of.....crushed his fuel pressure reg. to bump up fuel pressure by 2-3lbs. Pulled throttle bodies off vans for better flow, used a zinier diode to trick the ECU about overboost... ect.....
Old Oct 28, 2009 | 01:50 PM
cgeorge's Avatar
I went with OEM for my 2000 4Runner. It really didn't cost a whole lot more than the aftermarket ones.
Old Oct 28, 2009 | 02:05 PM
srozell's Avatar
Yep. I'm with you on that.
I figure, when I'm replacing something that lasted 20 years, there's harm paying a bit more to replace it with the same piece that will likely last another 20 yrs.
Old Oct 28, 2009 | 02:15 PM
4Crawler's Avatar
I find the Denso sensors have a longer tip that gets down into the exhaust stream better than the shorter tipped sensors I have seen from other mfgs. On my VW, I prefer the Bosch parts, but on my Toyota, I go w/ Denso, they seem to work the best.
Old Oct 28, 2009 | 02:34 PM
Kiroshu's Avatar
OEM-Denso
88sasturbotoy
Jan 30, 2026 01:57 PM
bighaydn
Aug 4, 2015 07:17 PM
87toyy
Aug 4, 2015 04:51 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
