Overheats - Calling all experts
Old Mar 9, 2006 | 04:07 AM
DOT3's Avatar
I had a coolant leak on the "Cylinder Head Rear Plate" so I decided to replace that gasket. While I was in there, I pulled the carb to rebuild, the EGR and intake manifold to clean and replace gaskets. I got it all back together and it runs good but it overheats. I tested the tstat and it opens, the fan is turning and the water pump has been working fine. The heater does not get hot at all so I shut it down before it got above 1/2 on the temperature gauge
What could I have messed up?
Old Mar 9, 2006 | 05:29 AM
fourwd1's Avatar
You may have an air pocket in the cooling system preventing proper flow of coolant. Park the truck so the nose is up hill, remove the cap, start it up and let it run till it's hot. The bubble should work it's way out.
Old Mar 9, 2006 | 05:35 PM
DOT3's Avatar
Yep, that was it. I just needed to give it a little more time.
She runs good.
justdifferentials
14
Jun 11, 2017 08:36 PM
Chicken12
Oct 14, 2015 03:54 PM
LCE_Performance
Oct 1, 2015 01:03 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
93RedKrawler
Sep 25, 2015 02:41 PM
