Overdrive Off ?
Overdrive Off ?
OK I have a 1995 4runner 3.0 4x4. My question is, how high can you go with the rpm with the over drive off ? You no, the rig will not shift before it reaches the right temp. So I don't want to push it not knowing what the rpm's should be. Thanks for the help.........
with your engine not being warm, you don't want to push the RPMS too high. I would start up your truck like a minute or two earlier and then take off. I would just avoid going above 3 to 3500 with the auto until your engine is properly warmed up. It doesn't take that long anyway, mine gets warm within 1 minutes warm up and 2 miles.
Well if you live where the temp doesn't get above 0 some days and the interstate is only a mile from your house, you don't have a lot options for keeping the revs down if you want to keep up with traffic on the interstate. I would get up to around 4000 but that would be my max. But I try to keep under 4000 all the time. Still takes awhile for it to shift when it is that cold.
Well, mornings here are normally around 50 so I can't say what I would do in that situation. Maybe just let it warm up longer? People get up in the 5000s all the time with their 3.0s. I KNOW I wouldn't ever go that high, especially when its cold. Mine has never been above 4 and that was due to a weird downshift.
I totally agree, the 3.0 LOVES to go over 5,000rpm.
I usually don't make a habit of doing it all the time, but if I am in a fiesty mood I will take her up to 5,500 rpm on 1st - 3rd, she defently has some power if you give'r
I love when some douche is trying to show off and I open the ol girl up, surprizes most people
Anyway, most people don't give the 3.0 its due it's a toyota motor and besides the lack of power pushing a large truck and the HG problem the motor provides impressive power for what it is. It loves the high RPM range for power unfortunatly most people need it down low. I wouldn't make a habit about taking it over 5 grand, but you can.
For the first year that I drove this truck I never took it over 3,000rpm.
Thats when I really felt the truck was a DOG.
I started to take it up to around 4000 then finally took it up to 6,200rpm (never again, that scared the crap outa me)
I usually keep it under 4 but like I said, somtimes I will open it up
muahah, stupid heeps
Speaking of... does anyone know the fuel injection shut off rpm? I mean, doesn't a fuel injected engine stop supplying fuel if the engine revs too high? Anyone know what that point is for the 3vz-e?
usually temps around 32 f or 0 c or lower will give you the shifting problems. let the rig warm up in the drive way for a couple minutes and maybe take the long way around the block before hitting the highway.
in the cold nasty weather you leave a little early any way, just in case! not sure of the weather you have in your neck of the woods, not too much different than what i exprience and taking the extra time and distance should help out.
lee
lee
Mine just seems to run out of breath (at least up here at altitude) above 5200 so I usually shift right around there.
3k RPM? LOL - mine'll barely move down there. I rev mine. Guess that's why I fall on the "c'mon, it ain't THAT slow" on the "just how 3.Slow is it?" threads.
Chris
