Overdrive Blues
Old Jul 26, 2015 | 05:59 PM
chuckross1957's Avatar
Overdrive Blues
Well it seems my overdrive has bit the dust permanently. I have lost it briefly in the past , it always came back. So I checked out the external electrical part of the system. It looks like I'm getting good voltage to the solenoid. I'm hearing and feeling the solenoid click. I was doing some research on the A43D transmission and it seems it is identical to AW70 transmission used on a lot of Volvos (except for the tailshaft/flange). It is funny, I've actually found more info about the overdrive on Volvo forums. There is a bypass plate for the solenoid that is sold for the Volvos, it keeps the transmission in overdrive full time. Also the Volvo solenoid works on Toyotas, except the plug is different. I was wondering If anyone has tried using the Volvo transmission on a Toyota, Apparently it isn't too difficult to swap the tailshaft parts. At this point, I'll probably order a bypass plate or a Volvo solenoid. http://www.turbobricks.com/forums/sh...d.php?t=291145
Old Aug 8, 2015 | 05:40 PM
I installed the Volvo bypass plate. Now my overdrive seems to be working ok. With the plate installed the transmission basically works like an ordinary 4 speed automatic.
Old Aug 8, 2015 | 07:28 PM
vital22re's Avatar
totally a bro
These systems will keep overdrive off if it thinks the engine has not sufficiently warmed up. Stuck open thermostat will do it. As well as a bad temp switch.
Old Aug 11, 2015 | 06:35 PM
4runnerx3's Avatar
Have you unplugged the computer for the tranny and see if you have OD? OD is when both solenoids are off.
Old Aug 12, 2015 | 11:38 AM
I'm not an expert on transmissions, most of what I have learned is by doing research on the internet. I haven't even dropped the pan on my A43D. There seems to be some confusion about the A340E and the A43D. As you can see in this link even experts can become confused. http://www.justanswer.com/toyota/8c3...utomatic.html# From my research I have found the A340E is electronically controlled and the A43D is not. The exception is the A43D overdrive solenoid is electronically controlled. By installing the bypass plate, you eliminate the electronic control for the overdrive function. So if I understand the A43D correctly, there is only one solenoid and that is the overdrive solenoid. Some folks, like me, were having problems with the overdrive dropping out very intermittently at interstate speeds. I believe the bypass plate can eliminate the issue in most cases. I suspect the overdrive solenoid was the problem in my case and I could have replaced it. But, I have never found a situation where I needed to downshift out of overdrive. And, by installing the plate I hope to narrow down the source of a very intermittent problem. http://www.ipdusa.com/products/4793/...oid-bypass-kit Note the "Product Description".
Old Aug 16, 2015 | 05:29 PM
4runnerx3's Avatar
I missed the 43D. Did the vehicle ever run hot before? What is the vehicle?
Old Aug 23, 2015 | 11:04 AM
It is an 86 2wd. I've never ran it really hot...but I'm not the original owner. No problems with the overdrive using the bypass plate. I'm reluctant to say the dropping out of overdrive issue is definitely and completely resolved because it was such a rare, intermittent issue before. I'm running the 180 superstat again. Also, I'm using a mix of Dex 6 (1 Quart) and Dex 3. I'm wondering how this transmission would do running straight Dex 6.
Old Jun 26, 2019 | 06:34 PM
nomad26's Avatar
Thanks for posting this I didn't use the plate I made my old solenoid work by grinding a slot between the two holes and replaced it . Works great
Old Jun 28, 2019 | 07:08 PM
Great to hear you solved the problem, I haven't had any more overdrive issues with mine since I installed the plate. One thing I was thinking about are the newer synthetic transmission fluids...I suspected they might flow better at cold temperatures. Better flow at cold temperatures might reduce the need for the overdrive solenoid. I found an article about Mobil 1 synthetic transmission fluid. I might give it a try the next time I change the transmission fluid. https://bestsyntheticoilguide.com/sy...ission-fluids/
Old Jun 28, 2019 | 08:07 PM
nomad26's Avatar
I used royal purple that was about 50 k ago I was thinking of putting in a fresh filter and oil and maybe replace the other solenoids . Maybe I will check out Mobil. The royal purple is pretty Pricy. Thanks again
Old Jun 28, 2019 | 09:24 PM
old87yota's Avatar
This is what I am going to use for my next Automatic Transmission Fluid change: https://parts.toyota.com/p/Toyota-Au...0718ATF00.html
Old Jun 28, 2019 | 10:19 PM
nomad26's Avatar
I may use that as well . Its not cheap either .
ashamsuddin
17
Jul 22, 2024 03:59 AM
nvwiggins
13
Jun 16, 2016 03:05 PM
1985 4Runner
Sep 30, 2015 10:17 AM
charlie_fong
Sep 27, 2015 10:06 PM
rmill05
Sep 27, 2015 01:43 PM
