Opinions on rear shackle lift for '93 pickup
Old Aug 13, 2012 | 10:47 PM
jsamarin's Avatar
So, I have a 1993 pickup with 32's and a t-bar crank, and I want to prop the back up about 1" to match what lift I've gained in the front. From what I can see, longer rear shackles (5.5" i2i compared to stock 3.5" i2i) will give me the lift i'm looking for, while keeping the same ride quality and reliability if you will. Is my logic correct? Are there any adverse affect to adding longer shackles to a stock suspension?
These are the ones im looking at:
http://www.lowrangeoffroad.com/index...kits-1802.html
Your opinion is appreciated!
Old Aug 14, 2012 | 08:56 AM
Discombobulated's Avatar
I don't think it would effect your ride due to your not really adding leafs or making it stiffer, but I wanna say it will change the angle of your axle a bit. Are your leafs in good shape? Reason I'm asking on my truck the rear is a little bit higher than the front so a TB crank would seem to even mine out, so if yours is sagging mayby some new leafs would bring it up?
Old Aug 15, 2012 | 10:12 AM
abecedarian's Avatar
Should work. I had to add shackles to both the 91 2wd and 88 4Runner when I did the lits on them to make it level- we don't care for the pre-runner / desert runner look.
It didn't noticably affect the 91's driveline angle, but on my 88 it did; I 4-5" lift springs on too so had to remove the wedges.
As far as handling, the 91's solid but the runner does a little more wallowing in cross-winds than it did before.
duckhead
Jul 17, 2015 04:45 AM
cchinny
Jun 25, 2015 08:11 PM
Niameyrider
Jun 25, 2015 05:50 AM
Garth
Jul 24, 2002 09:45 AM
nrgetic99
Jul 18, 2002 10:45 AM
