Ongoing 22RE issue, Only the Greatest of mind should enter here!! :)
#84
Trust me, this thing has been gone over a dozen times. Thanks for the input though!
#85
Ahhh! Thank You! This is the very problem I'm having right now too. Live in CA, 95 22RE. I blew a headgasket a while back and fixed it since then my car is running lean just like this. It has killed my catalytic converter. I ping on the highway. White plugs the whole nine.
Here is what I've done. Checked: Ignition Timing, Valve Clearance, Mechanical Timing, Rebuilt/cleaned injectors, New plugs, new wires, Cleaned EGR(during rebuild), New Head, Valves etc...and yet it continues to ping.
These are the things I've yet to test/do: Replace Fuel Filter, Test AFM, Test O2 sensor Good luck everyone I hope we can solve this.
#86
Interesting thread. This sounds like my 91 too. I had white plugs, lean as heck, eats o2 sensors, bad mpg, bad power, high Nox, replaced ignition, timed 1000 times, new fuel filter, two different afm's and checkedout.
I never figured it out so i sold it. Please figure this phantom 22re problem in hopes of saving people like me from havibg to thow in the towel. I wouldnt have sold it but if you cant pass aircare then you cant insure it which means it has to go
#87
I just took my AFM off and did the sweep test and took all the readings on my digital ohmeter. Every single thing checks out. Sweeping the vane and checking the resistance between any of the contacts reveals nothing out of the ordinary like dead spots where resistance approaches infinity. Sometimes I would sweep to track the wave pattern between E2 VC and I would see it. Occasionally when I went over it it would randomly his 1.4 1.6 kohm but when I'd backtrack to find it again it wouldn't be there.
One more thing checked off the list.
#88
Just tested my TPS It is all good. Here are the readings:
VTA-E2 .57Kohm @0mm, 3.1 Kohm at WOT
IDL-E2 no equipment to read but almost instantly went to infinity just as specs would imply
VCC-E2 3.86kohm iffy here but super close to low limit of 3.9 kohm
One more thing to check off the list
#89
#91
Bump for the guys still working on this. I don't want this thread to get buried. I check the codes tonight on my car. None MIL blinks every half second as if nothing is wrong. Any other updates for those working on this problem still?
I hate to say it but my working theory for this problem is the headgasket. I should have gotten the OEM gasket I think. My theory is the head gasket is either too thin or the coolant passages to small to adequately cool the head and it's creating hot spots.
It seems to me to be the only explanation because I have checked all the things responsible for fuel and air and they all work. If something was malfunctioning it would throw a code.
#92
I did not find the dead spot in the sweep test till I used a analog meter. I have not yet replaced the afm for anyone that wants to know. I'm still looking for one local so I can test it myself.
#93
UPS is supposed to gift me a used hopefully good condition AFM today and I will see if it fixes the problem. My fingers are crossed because after this I don't know what to do. I will have ruled out every single air fuel cause it could rationally be leaving me to confront my final theory that I did the head and used a non OEM headgasket. Perhaps it could be caused by blockage with insufficient cooling over the head leading to hot spots that cause the ping. This doesn't however deal with the issue of a lean condition(high egt) that supposedly fried my last cat.
#97
I would hope that you would not get any ping at all. I don't know the time frame for the ecm to re-learn but make sure any timing tweaks you did to try to get rid of the ping are put back to spec and the codes cleared.
#99
I know you probably did this, but did you test the replacement afm with a analog meter doing the standard fsm test and sweep test? I'm not as excited about getting mine now......
#100
Hey Melicha, I re-read your posts i saw you used a digital meter to test with, In post #92 I said I could not find anything wrong till I used a analog meter(for the sweep test). I also had the cover off mine so I could test it under power "key on" and that's when I found the voltage drop. IneternetRoadkill talks about this somewhere in this thread and in others. So hit it with a analog meter and get back to us.
