OME to fix rear sag
Old Dec 29, 2013 | 09:53 AM
gotduhka's Avatar
OME to fix rear sag
Hi all, I have a 94 4x4 pickup that is sagging out in the back. Given I have a camper top and a carpet kit in the bed, but I would like to fix this using the best practices available. I was looking at throwing these in there: http://trdparts4u.toyotaofdallas.com...dproduct=-8838 but am not sure if I would have to get new shocks along with it and didn't know if I would have to do any modifications to the front end (torsion bar?)... something I don't want to do.
Thanks for any help.
Old Dec 29, 2013 | 10:26 AM
KirkPayne's Avatar
Originally Posted by gotduhka
Hi all, I have a 94 4x4 pickup that is sagging out in the back. Given I have a camper top and a carpet kit in the bed, but I would like to fix this using the best practices available. I was looking at throwing these in there: http://trdparts4u.toyotaofdallas.com...dproduct=-8838 but am not sure if I would have to get new shocks along with it and didn't know if I would have to do any modifications to the front end (torsion bar?)... something I don't want to do. Thanks for any help.
I was looking to buy these too. I'd like to see what people have to say about them
Old Dec 29, 2013 | 11:50 AM
Laurentian's Avatar
OME or NWOR, which ones should I get ?
Looking for a 1.5 to 2.5 rear lift on an IFS pick-up.
I think NWOR sources north american components which makes
me lean towards those.
Any ideas ?
Old Dec 29, 2013 | 12:36 PM
gotduhka's Avatar
Hey thanks Laurentian... I just found these factory replacement springs from NWOR, can't really be more straight forward.
http://www.northwestoffroad.com/parts/2stage.php
Old Dec 29, 2013 | 01:01 PM
Laurentian's Avatar
Cool, I'm going to order the 2" lift rear leaf spring in January when they get back.
Already have a set of Sway-Away torsions on way in from them.
Old Dec 29, 2013 | 01:20 PM
94 SR5 Mountaineer's Avatar
I have read bad things about NWOR's customer service on these forums but have no personal experience with them. I did however just put OME rears on my pickup. I ordered the medium duty leafs, u bolts, and shocks from 4 Wheel Parts. These springs were advertised as 1.75" of lift. I'd recommend following up with a LSPV bracket, shackles, and greasable bolts from 4Crawler. I also drilled out my front hangers to accept the same bolts (from 14 to 18 mm).
Before: (33x10.50 tire with 3" body lift)
After: (along with 5 cranks of torsion bars which added about an inch at most)
I could go higher with the t bars, but I plan on adding BJ spacers in the near future so that I can have a level ride without having the them cranked so much.
Old Dec 29, 2013 | 01:30 PM
Laurentian's Avatar
Check out these ball joint spacers, steel and by the look of them you
won't have to clearance your A arms ( I am hoping ) :
http://www.krfabs.com/product_detail.php?productID=11
Old Dec 29, 2013 | 01:32 PM
A better view of the components:
Old Dec 29, 2013 | 02:11 PM
Greg_Canada's Avatar
Any ideas ?
If you are in Quebec, go to Montreal and pick up the OME stuff from www.ouipack.com ... save a lot of shipping $!!!
I would go for OME any day over NWOR. They make decent parts but customer service is not their strong suit!
Old Dec 29, 2013 | 02:17 PM
Laurentian's Avatar
Thanks Greg, I tried.
Ouipak has been shutdown on OME product !!
I did call / email Tony earlier this month and
he sent he to OME usa, sorry.
Old Dec 29, 2013 | 02:18 PM
Laurentian's Avatar
NICE, love it !
Will go same route !
Old Jan 2, 2014 | 02:05 PM
Laurentian's Avatar
'94 SR5, is this the part number you used for the OME rear leafs ? :
CS019R ( from TRD Texas )
Old Jan 2, 2014 | 03:08 PM
SkybluYota's Avatar
I had OME stuff on my 4Runner and loved it. Great ride quality. I bought the "kit" with the T-bars, rear coils, steering stabilizer and all four shocks.
Old Jan 2, 2014 | 04:07 PM
Bigblock's Avatar
I just added a leaf to my stack and solved all my problems. Got the extra leaf from a junk truck(ranger I think).
Old Jan 2, 2014 | 04:59 PM
Yep that's the one. Don't forget 2 bushing kits and 4 u bolts (also OME)
Old Jan 3, 2014 | 07:19 AM
Laurentian's Avatar
OK thanks all good.
I'll post up in this thread later in new year once the mods are done !
Old Jan 3, 2014 | 08:55 AM
highonpottery's Avatar
I run OME suspension on my 93. got everything from TRDParts4U several years ago and have been happy. I got Dakar medium leafs, 2x bushing kits, u-bolts, 4x shocks, 1x steering stabilizer, SDORI BJ spacers, and a Sonoran Steel IFS truss all from them. I chose not to get new shackles at that time because theyre in great condition and I didn't want extra height -- now I'd say I'm ready for some new shackles now that I've added more front end height to clear my tires. I'd recommend you make sure your idler arm bushings are in good condition as well as everything else up front like all your joint-ends, since you'll now be changing angles on everything - also, it'll keep the steering nice and tight. Firestone Lifetime alignment was a great investment for me wheeling IFS and making changes over the years, why pay more than once?
LSPV brackets can be easily made yourself, but if there's a kit then just get that it's faster (I think I actually just bent the arm more and adjusted the threads and it's been fine since it's not a lot of lift). Think about your plans for the truck - if you want to wheel a lot, consider getting a u-bolt flip kit now and install at the same time or you'll be buying ubolts twice (but you'll need a welder). For me, I noticed the stock shock setup was my limiting factor for flex - now that i've done the ubolt flip and triangulated the shocks, everything is better and i get several inches more down-travel -- also, the OME ubolts had VERY long threads and will need to be cut off after install or they'll hang pretty low under the axle and catch on everything.
IMO, a ~2" lift with 33s is pretty much the perfect stance for a weekend warrior toyota pickup. Recently found this pic of my truck from Squaw trip a few years ago - you can see the need for maybe 1" more in the rear (needs a 5.5" shackle) -- truck sits level at 22.5" from center of axles to bottom of f/r fender lips:
Old Jan 3, 2014 | 10:25 AM
Laurentian's Avatar
Thanks HighOP,
Are you running bigger torsions ?
Did you remove the sway bar ?
Nice pic, looks like a great trail !
Old Jan 3, 2014 | 12:48 PM
decided to skip the larger OME torsion bars because I don't have a heavy winch+bumper up front to combat the extra spring rate. I also removed my swaybar because, again, there isn't extra weight up front and I wanted all the IFS flex I could get when out wheeling so I could keep my traction since IFS likes to 3-wheel and I have an open front diff - also, the stiffer OME shocks and new stiff leafs pretty much equalized out what the swaybar did for the old soft suspension. You can always add the t-bars at a later time. I think you'll be happy with the new suspension, just remember the leafs take a little while to settle so don't be alarmed at the height gain when you first install them (especially if you're sagging now)
Yeah, Sqauw Ridge was a great trail, but sadly got closed because of Environmental Impact Study or some BS like that since there are a few meadows that get driven through. I hear parts of it are open though.
Road Bull
Oct 10, 2015 04:55 PM
Nickdigg
Jul 7, 2015 06:04 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
