Oil leak question.
Old Sep 26, 2013 | 06:07 PM
Kiroshu's Avatar
^--x3
So is mine on my 4runner changed it so many times, I've been meaning to place it back where its suppose to be for years.
Old Oct 7, 2013 | 08:05 AM
Nuckinfut's Avatar
And so it begins!
Old Oct 11, 2013 | 08:42 PM
Nuckinfut's Avatar
Progress!
Old Oct 11, 2013 | 09:17 PM
Nuckinfut's Avatar
So, tearing my intake off there is coolant in the intake. Any ideas? It has to be from the throttle body hose that comes into it. Does that have a gasket?
Old Oct 13, 2013 | 07:59 PM
  #25
Kiroshu's Avatar
There are multiple coolant passages that navigate through the intake manifold.
Unless we are talking about coolant in the air intake passages and the intake ports in the cylinder head....
Then you may have some issues there...
Old Oct 14, 2013 | 09:19 AM
  #26
central4runner's Avatar
When we took the upper plenum off there was coolant sittin in the intake runners of the lower plenum. He had been sayin that he was smelling coolant (sweet smell) after driving it but no leaks than i found that coolant sitting in the lower intake and the intake ports were pretty clean (steam cleaned by the coolant?). I know there is a water tube that bolts to the under side of the lower intake but the coolant was sitting above that so i am assuming (we all know what happens when you do that) that it was coming from the coolant that circulates through the TB?
Old Oct 14, 2013 | 09:48 AM
  #27
scope103's Avatar
Doesn't the coolant circulate through the head? Wouldn't a crack in the head let coolant drain back into the intake manifold?
This is why the Machine Shop will perform a pressure test on the head.
Old Oct 14, 2013 | 02:47 PM
  #28
Kiroshu's Avatar
Coolant in the intake manifold air intake passages could indicate a number of leak areas:
-Cracked/damaged Cylinder Head
-Cracked/damaged Cylinder Block
-Cylinder head gasket
-Lower Intake manifold gasket to cylinder head leak(s)
-Cracked/damaged intake manifold
Coolant leaking from the throttle body into the intake is unlikely but possible if the throttle body is damaged or cracked.
Unless of course is was "spillage" during disassembly... but also mentioned "clean" intake passages...
Old Nov 14, 2013 | 07:37 PM
  #29
kirkerik's Avatar
Any luck, nuckingfut?
Old Nov 14, 2013 | 09:50 PM
  #30
Nuckinfut's Avatar
Well we pulled it out, got it all put back together and in. Runs great. Still has a leak. I do now know where it's coming from though. So there is a small crack in the timing cover. Probably from the "hidden bolt" by the timing chain being over tightened. So I need to replace that.
Old Nov 14, 2013 | 09:56 PM
  #31
YotaSnap's Avatar
I feel for you. I cracked mine right after a rebuild so I threw rtf on it and said screw it. Good luck man.
Old Nov 14, 2013 | 09:59 PM
  #32
Nuckinfut's Avatar
I tried to cover it with JB weld ( I know it's lazy) just to get by with it till I order a cover. But it's not really working. Couldn't reach the whole thing without taking off the power steering belt and bracket.
Old Nov 14, 2013 | 10:02 PM
  #33
YotaSnap's Avatar
That must be a pretty large crack then?
Old Nov 15, 2013 | 06:57 AM
  #34
Nuckinfut's Avatar
No it's not that big it just wraps around (kinda hard to explain) and I could only reach half of it without taking some stuff apart. I'm just going to order a timing cover and replace it.
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
