IS oil expander ring SPRING necessary?
Old Jul 18, 2011 | 01:56 PM
coltonstewart's Avatar
Question IS oil expander ring SPRING necessary?
93 pickup 3vze:
I bought Hastings rings on the web and now realize how different the oil ring expanders are compared to the originals... I also noticed the spring or interior wire is not present, is it necessary? Perhaps I should use the originals with the new rails..
Old Jul 18, 2011 | 02:20 PM
snobdds's Avatar
Short answer Yes.
How else is oil supposed to lubricate the cylinders?
I guess a better question is why don't you think you need it other than they look different?
Old Jul 18, 2011 | 02:42 PM
I was not talking about the necessity of the oil ring itself, but more about he little wire that is bent into the original oil expander. its called the inner-spring in the abridged instructions that came with the rings.
that attatched picture shows the new one and an old one.
Old Jul 18, 2011 | 02:56 PM
the new rings dont even have holes for an inner-spring..I guess what it comes down to is which type of oil expander is better? and is the set of rings designed for its exclusive set cooperation for efficiency?
Old Jul 18, 2011 | 02:58 PM
snobdds's Avatar
I don't have a whole lot of experience with hastings...ok none, but I would follow hasting's instructions to a "T". Hopefully they mention it...
Old Jul 18, 2011 | 03:23 PM
MudHippy's Avatar
Hastings invented the multi-piece oil ring. So if they came from hastings like that, then that's the way they're supposed to be.
http://www.hastingsmfg.com/ContentDa...x?Contentid=71
You should definitely NOT leave the oil control expanders out, or even mix and match brands/types of oil control expanders with oil control rails/rings of a different brand/type. They're in NO WAY interchangeable like that, and THEY ARE NECESSARY.
Just use the new Hastings rings how they came. That's what I'd do.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
calderp
Jul 27, 2015 09:58 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
