odd noise from rear
Old Feb 20, 2007 | 05:42 AM
Robert m's Avatar
odd noise from rear
when going slow and turning, hitting a bump in the road , or going over a speed bump, the rear of my truck makes a loud creaking noise... what is it? only think i can think of is the leaf spring bushings.
Old Feb 20, 2007 | 05:45 AM
silversup's Avatar
Definitely a bushing back there.
Spring, sway bar etc...
But once you replace one.....you will be replacing them all.
Old Feb 20, 2007 | 06:02 AM
MMA_Alex's Avatar
my spring shackle bushings were completely shot (you could tell from looking while they were still inplace), and it would make a loud creak while backing over a bump even at slow speeds.
You can look for any obviously worn bushings, and spray silicone lubricant onto bushings to see if it quiets it up.
Old Feb 20, 2007 | 06:14 AM
GSGALLANT's Avatar
It could be the plastic pads between the leafs that are worn down. A little grease between the leafs may help you for a while.
Jeffreynmandy
Jul 18, 2015 08:26 AM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
