O2 sensor part # - 3.0
Old Feb 28, 2013 | 01:10 PM
adamthedroog's Avatar
Does anyone know the part # for a heated oxygen sensor?
Old Feb 28, 2013 | 01:23 PM
scope103's Avatar
Sure. 89465-39745 is a part number for "a" heated oxygen sensor.
But whether it would fit your vehicle depends on a few things you haven't told us.
Old Feb 28, 2013 | 01:34 PM
What do you need to know?
Old Feb 28, 2013 | 01:52 PM
MudHippy's Avatar
1990 4Runner 3VZ-E?
89465-39355
Old Feb 28, 2013 | 03:51 PM
scope103's Avatar
Also need to know if you want the upstream or downstream sensor. (usually California only)
Old Feb 28, 2013 | 08:25 PM
I thought heated was upstream and sub heated was downstream.
Old Mar 1, 2013 | 06:46 AM
MudHippy's Avatar
That's backwards. If sensor 1(upstream) were located at, or near, the exhaust manifold there would be no need for it to be heated. If sensor 2(downstream) were located after the TWC(not at, or near, the exhaust manifold), then it would need to be heated.
http://www.autoshop101.com/forms/h37.pdf
However, in this case, both would need to be heated. Due to the location of the TWC. Essentially, because they would both be in the "downstream"(not at, or near, the exhaust manifold) position. Since sensor 1 is already located away from the exhaust manifold in the exhaust pipe just before, and upstream of, the TWC. So sensor 2 would need to be located just after, and downstream of, the TWC(even further away from the exhaust manifold).
http://personal.utulsa.edu/~nathan-b...79threeway.pdf
Old Mar 1, 2013 | 07:11 AM
Austin Marr's Avatar
I have a used O2 sensor from a 3VZE that was just infront of the cat that i dont need anymore, only like 2yrs old. I'd give it to you for 10 bucks plus S&H
Old Mar 1, 2013 | 07:23 AM
Gamefreakgc's Avatar
I've got a terrible universal O2 sensor you can have if you live near Sacramento
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
smiley52
Jul 11, 2015 05:16 AM
wilbertd
Jul 6, 2015 07:39 AM
