Not upshifting cold
Not upshifting cold
My 94 automatic 4Runner is not upshifting when it's cold, after about a mile or 2 it shifts fine. I took it to Cottman's, they said it had too many codes and so they believed it had an electrical problem and referred me to a local garage. The mech there cleared the codes and none came back, he believes it's the transfer case that is staying in low and not the transmission. He was stumped so problem was not fixed. Has anyone experienced the same problem??
Thats pretty normal for an auto tranny, and since you are not asking in the newbie section ill have to say search and learn. The auto tranny will keep it in lower gear to bring the operting temp up to normal. You may notice that your rpms will go slightly higher for each gear as well.
Check the throttle cable, or rather the cable below it, that tell teh tranny what to do. ALso, Check your TPS, it makes a huge difference in terms of what the computer tells your tranny to do.If that cable is loose, snug it up, but if it is too long, you'll need a new one, they stretch
It is normal for this particular auto tranny to 'lock out' overdrive until the engine gets up to normal operating temperature. Once you hit operating temp, it will shift into 4th. If this is the occurance you are describing, it is normal.
If your tranny is having problems through all of the gears, something is wrong.
I have only owned this 4Runner since May, it has 175k but looks and runs great. The OD has always not shifted until it reached operating temp. But this is something new, can only get up to about 30 mph @4000 rpm. After about a mile it will shift and work great the rest of the day, the next morning -same story. I will check the cable and TPS, that makes more since than the transfer case. Thanks for the replies!
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
bryan34w
12
Sep 30, 2015 02:50 PM
