Not sure exactly what it is, but something doesnt look right
Old Jun 16, 2008 | 10:14 PM
t0mwat3r's Avatar
This is the passenger side, does this not look right?
this is the drivers side
Old Jun 16, 2008 | 10:16 PM
DeathCougar's Avatar
Thats def bad. You need to replace your idler arm ASAP.
Old Jun 16, 2008 | 10:33 PM
Ezrider_92356's Avatar
i wouldent say asap, i would say before you drive the vehicula even 1 more time, that is an accident waiting to happen
Old Jun 16, 2008 | 10:42 PM
t0mwat3r's Avatar
but the drivers side is fine correct?
Old Jun 16, 2008 | 11:37 PM
stormin94's Avatar
Nope, looks good to me.
What exactly are we looking at?
Old Jun 16, 2008 | 11:42 PM
t0mwat3r's Avatar
Old Jun 16, 2008 | 11:48 PM
stormin94's Avatar
Ok, on second thought, you should probably replace that part as soon as possible.
Old Jun 16, 2008 | 11:56 PM
thook's Avatar
Holy schmidt! That thing is shot! After you replace it, get your alignment checked. You might also wanna check your tie rod ends and see if any of those are bad.
Had any accelerated tire wear issues, lately?
Old Jun 17, 2008 | 12:06 AM
t0mwat3r's Avatar
i haven't had any abnormal tire wear, So to fix this problem i would need to replace my idler arm and have it aligned?
Old Jun 17, 2008 | 12:20 AM
Jay351's Avatar
YES! Replace the idler arm asap, looks like the stud is gonna pull right out of the arm.
Old Jun 17, 2008 | 12:26 AM
thook's Avatar
It already has! All it would take is just enough droop on that side to totally displace it. Eeeek! is right!
Old Jun 17, 2008 | 02:16 AM
SwampThing's Avatar
Pfft. Who needs idler arms. SAS that beast!
Old Jun 17, 2008 | 02:17 AM
SwampThing's Avatar
At lease, that's the argument I'd use if I wasn't in control of my own check book
Old Jun 17, 2008 | 02:35 AM
Offie's Avatar
Wow, that really looks bad, I bought this set on ebay, good quality.
about 3 hours and it's all new
Old Jun 17, 2008 | 03:33 AM
mt_goat's Avatar
Don't drive it! Call a tow truck if you can't replace it yourself. BTW there is a recall on the center link thingy. https://www.yotatech.com/forums/f116...8-t100s-66901/
Old Jun 17, 2008 | 03:59 AM
Lysmachia's Avatar
X2. How much lift do you have? If I understand correctly a lot of lift with IFS can cause Idler arms to fail often. Once you get a replacement, I think you can beef it up by getting a brass bushing set, though they often have to be machined once you get them to fit right. TC knows more about this than me so maybe he'll chime in.
Old Jun 17, 2008 | 04:59 AM
toytech76's Avatar
I totally agree, replace ASAP. As for the recall, its only 89-95. His looks to be pre 89
Old Jun 17, 2008 | 08:29 AM
mt_goat's Avatar
Oops, my bad.
Old Jun 17, 2008 | 08:40 AM
Chuckracer's Avatar
Idler arm swap won't affect the alignment.
Old Jun 17, 2008 | 09:27 AM
spdjnky's Avatar
Looks exactly like mine did! At the time i had no lift at all. I found mine when doing a routine check and had no idea how long it had been like that before I noticed...probably 2-3 weeks? thankfully I had a spare and replaced it that night.
I agree with Chuckracer, replace and no need for alignment.
